muvro
Hi all,
Just wondering what rim options are out there that are under 400g.
I currently run Mavic XC717 rims with Hope Pro 2 hubs.
The reason I want to change is I am always getting leaks around the valve hole. The 717 comes with a 9mm hole and I run a FRM tubeless conversion kit with a French valve. The problem is the valve isn't wide enough to properly seal the hole. I've tried an extra layer of rubber under the valve, poly-urethane glue and a few other things, but they keep leaking. Added to that, the rubber tubeless strips and the tape all add weight. So looking to drop weight and ditch the leaks.
Any help would be appreciated.
Cheers
Cheers
