Washers (& Bolts)
Tazed
Can anyone recommend a supplier (in Melbourne, if possible, but anywhere will do) who can sell me a couple of stainless washers (not a bag of 100!).
I'm specifically looking for inner diameter of 10mm, outer 15-20mm, 0.5mm thick.
Any help appreciated (and yes, I searched and will also hit up the Yellow Pages tonight).
Cheers!
downhiller_1
wholesale bearing in Melton will have them... thats if you want to travel... i can look tomorrow for you to make sure!
Give the guys at Southern Bearings a buzz. Use to also stock an assortment of fasteners as well.
They're also great for sourcing odd size needle roller bearings, sealed cart. etc.
33 Mollison St, Abbotsford. (03) 9429 1222
Good luck.
Otherwise check out Coventry Fasteners. Never had a problem sourcing sml numbers of washers or nuts and bolts. There was one conveniently located 20m from Southern Bearings but am sure they've since moved.
Zarken
If anybody in sydney knows a good place as well that would be much appreciated.
Mostly to stock up on retaining washers for the Hayes 9 levers, not worth buying an entire kit just to replace them.
Tazed
bunnings sells washers and bolts go check them, i just scab mine from work :p
Unfortunately not the right sizes...!
Thanks for the info guys, and thanks Rayza for the offer.
Hope to get this sorted out soon now.
Cheers!
