GrubNut
I've got a problem with my rear shifting that I haven't been able to solve. One day the bike just started misshifting, skipping, riding up on the ramps, and dropping or gaining a gear. No matter how I adjusted the cable just couldn't get rid of the problem.
Happens intermittently.
I adjust the hanger. No fix. Replaced the hanger. Nope.
So I replaced the derailleur thinking it looked a little skewed and there's play in the linkages.
Guess what. $120 later problem persists.
What seems to be happening is that it is shifting too much. On the inner cogs the cable is too tight and the outer cogs the cable is too loose. So its tending to shift down on lower gears and shift up on higher gears. Weird.
So all that's left to replace is the shifter.
Anyone seen this behaviour with a worn shifter?
It's a Sram x9 grip shift. And yes the cables and outers is replaced and lubed (well I use graphite for cables.)
Any ideas?
Any ideas?
