New Bike Day.
Gonna strip the paint in that area, just to make sure.Noooooo
I would do the same mate, paint a thin line of paint stripper on it and get a clean look at it. Possibly looks like the weld has moved.Gonna strip the paint in that area, just to make sure.
Hopefully it is just typical shitty Transition paint, but definitely not looking promising.
If it's not a crack I'm going strip the whole frame and clear coat it.I would do the same mate, paint a thin line of paint stripper on it and get a clean look at it. Possibly looks like the weld has moved.
Good pick up, when #2 son broke his first Canyon frame, we found 3 serious cracks on the broken frame, all in different places.
If its nothing, stick a piece of thin black or carbon fibre tape over it and heat it on to blend with the frame/weld shape.
Shitty situation.
I had very similar on a carbon fatbike frame that was making a creaking noise, I swore it was the BB and swapped it 3 times... lots of BSA30 Cinch spares now. I painted a 5mm line where the crease was, revealed a separation and sent it to the chi manufacturer. They sent me another frame after a year of use.If it's not a crack I'm going strip the whole frame and clear coat it.
Go and see Rocky in NDT to be sure?If it's not a crack I'm going strip the whole frame and clear coat it.
Well flicked an email to Transition, guy seems to think it is just clear coat cracking. Paint stripper will confirm either wayGonna strip the paint in that area, just to make sure.
Take the seatpost out, and spray some wd40 inside the seat tube. If it's cracked the wd40 will mix with the aluminium dust and an obvious black stain will emerge on the outsideWell flicked an email to Transition, guy seems to think it is just clear coat cracking. Paint stripper will confirm either way
Good idea!Take the seatpost out, and spray some wd40 inside the seat tube. If it's cracked the wd40 will mix with the aluminium dust and an obvious black stain will emerge on the outside
Well then...If it's not a crack I'm going strip the whole frame and clear coat it.
Looks ok ? I can't see a gap on the photos ?Well then...
So you still have power out there John?
Yeah can't see anything untoward in the flesh either.Looks ok ? I can't see a gap on the photos ?
Black heatable tape and cover the stripped paint.
Yeah only just got reception and internets about 50min agoSo you still have power out there John?
Seems a lot won't for a while.
Near the youies apparently!
Yeah, you have to slightly unscrew the tips on the cheap nozzles to get them to release sometimes.Following on from a truly shit day yesterday...
Time to grease up the mower deck, well a bit overtime really. Couldn't find my nice MacNaught grease gun. Hmmmm. Not in the usual several places. #1 advised that he was using it at a mate's place and likely left it there accidentally, will grab it on the weekend. Not happy Vanessa. Anyway can always find a use for another grease gun. By now it is after hours so dropped into Bunnings and bought a Kinchrome clone of the good MacNaught one. Fill it with grease and it won't bleed. Followed the destructions and a video and there is a big old air pocket in the pump unit somewhere. Pulled it all apart and spooned grease into the pump and reassembled. Still nfg though it did work long enough to do one shaft bearing. Repeat process and look again at the Kinchrome video. See comments where about half the people say what a shit design it is and won't bleed properly. The thing has three bleed points (!) AND the hose connection. Work out lowest to highest and bleed/pump/scream at each. Barely a fart from two. Ahhhh. Success go to fill the next bearing and after 3 pumps it is all flaccid again. Almost angry by now. Repeat all that shit and it farts a little bit of air. Anyways it seems to be working and I go back to the second bearing. Go to remove the gun and it wont release. Cannot really get enough angle on the nipple due to the design of the shaft and pulley but off it comes. Go to fit it to the next bearing and oh dear the nipple is still in the nozzle. Close look and the nipple has sheared off at the top of the thread. Getting mildly pissed by now. Remove knackered nipple and do the rest of the bearings. Back to the broken one, grab the ezyout and find the right one is broked. WTF! Next size up fits ok and despite being loving and gentle just strips out the centre of what is left of the nipple. Too dark now to worry. Repair is to strip the blade off and pull the assembly and drill and tap to suit. Or grab another shaft if it isn't $34M like most Kubota parts.
Faaarrrrrkkkkkkkkk!!!!!!!!!!!!!!!!!!!!!!!
