What happned to Saint's?
i had M810 saint to xtr combo and now the M820 saints on my bike. ive always bled mine from the caliper up to the lever. wound the adjuster screw out and until clean and no bubbles. ive had no issues with power of mine. front lever looses feel when left sitting on its side but comes back after pumping it back up. hope that helps
Did you LBS use the newer titanium barb hose insert, or the older brass one? The new levers are designed to use the ti barb with a larger bore to increase fluid flow. If you use the older brass insert with the smaller bore the brake can feel like ass.
Also listen to willsy - you can't get a proper bleed without the bleed tool. You may get close, but the tool works every time. Costs $7 too, which is hardly a stretch.
I'm over saint brakes....I just cant get my old 04's to work as well as my 810's. I mean, they are fine for my DH bike, but wheres the WOW factor of the later models?
