Replace all spokes. Go for double butted 2/1.8 Sapim or Dt spokes and brass nipples.82kg, back wheel, rim is good...
I will replace the lot... Do I do the rest with the same straight 2.0mm from the LBS @ $2 ea? Or should I get a set or something better?
Just want it to be reliable and not constantly replacing spokes/tensioning
I've recently bought spokes from Dirt Works, was $65 delivered for 36 Pillar PSR2018 spokes. Would be cheaper if you buy more, they have a $15 flat rate postage fee.Cheers, wheres a good place to buy spokes?
YesFont worry, phone started working, but another question, is this just a normal hope hubs with 12mm spacers
This is a brand new meter and first wheels built using it. I had a feeling it wasn’t reading correctly but that confirmed it. Seems to be better after backing off the screw though.Can't say I've encountered that one before. Have had springs go soft, which will give falsely high readings, then they break....
Sapims don't have a marking on the head, its close to the j-bend.I snapped another spoke yesterday which went through the rim strip and flatted the tyre... that's 3 in one week. Snapped about an inch up from the j-bend.
I decided to replace the rest with the same DT Champions I've been getting from the shop, as I'm riding every day at the minute and didn't want to loose time waiting for spokes.
I've just looked at what they have given me and they're not DT's, there's no marking on the head.
I'm planning on taking them back and just ordering a full set of DT Comps online (they wanted $6 a spoke for comps???) , or am I being pedantic and just use what I've got and they will be fine?
You can order directly from Dirtworks if you don't want to use the ebay store just add to cart and go to check out, you will create an account at checkout. Will save on doubling up postage if you buy more than one item.Sapims don't have a marking on the head, its close to the j-bend.
Pillars and Dts have head markings.
Dirtworks have an Ebay store where you can order spokes and nipples from.
See
https://www.ebay.com.au/itm/254421938249
Measure the length firstI can't see any markings at all on them.. considering they charged me $60 for 24 no name spokes I guess I'll return them and get some DT comps.
