Daisy
I’ve tried to find EXACTLY where to apply lube to the chain but many online pictures/videos don’t show this.
It appears to be a common mistake to apply lube to the outside of the roller. Also, to apply lube whilst chain is on the sprocket.
Below is from Sheldon Brown website & I believe this to be true & accurate: http://sheldonbrown.com/chains.html
“There are three points where a chain needs lubrication. First, and most importantly, the link pins need to be lubricated where they move inside the inner links as the chain bends and straightens. Second, the insides of the rollers need lubrication to let them revolve freely around the bushings as they engage and disengage the sprocket teeth. If the rollers don't roll, they slide along the sprocket teeth, causing accelerated sprocket wear. Third, the surface where the outer side plates overlap the inner side plates can benefit from lubrication as well, although this contact surface is much more lightly loaded than the first two.”
“Many cyclists oil their chains by spraying, usually aiming the spray can at the rear of the derailer cage, because this reduces the risk of overspray getting on their rims or tires. In my opinion, spray lubricants should not be used on bicycle chains, because they get too much oil where you don't need it and/or too little where you do.
Most of the dirt & grit that contaminates a chain is stuff that is thrown up by the front tire. This lands on the outer circumference of the chain. For this reason, you should always oil a chain on the inner circumference, the side that faces the sprockets. This decreases the tendency of the oil to carry crud into the interior bearing surfaces of the chain. The best way to apply the oil is with a drip-type oil can, along the top of the lower run of the chain. This applies the oil to the cleanest part of the chain.”
From what I understand lube should be applied to the area as per below chain close up (red circles) on both left & right sides, as this will get to the 3x areas of chain mentioned by Sheldon.
Do you agree ?
Do you agree ?
