Also, are the places listed in previous posts above also good places to get these posts?
- Avoid 'stealth', as ill need to route cable externally
- 30.9mm for my Yeti SB66
- Im 6ft1, and like to drop the seat real low for decent - think I need the longest length with most travel?
Starting with length ... I'd recommend at least 150mm ... We are hoping KS 175mms will be dropping before March ... but no firm date yet soz.
External KS posts from top of the line to entry level
LEV Circuit - wireless ... available hopefully prior to March 2017 (not a firm date)
LEV (we also call this
LEV Ti)- Carbon and Ti bits ... 150mm in stock
LEV DX - very similar performance to the LEV ... except they save money by using Alloy instead of Carbon or Ti ... plastic for the remote port instead of alloy ... a fixed head instead of an adjustable head ... this affects how you position the remote port vs the saddle nose ... in short the LEV DX is set and forget at 45 deg on the right side ... LEV is adjustable 360 deg around the seat tube.
Dropzone R - remote cable attaches at the saddle ... 15mm offset ... under saddle LEVER versions also available if needed.
ETEN R or ETEN L - R = Remote L = Lever ... work horse ... circa 768g ... steel cartridge so needs a bit more care
if you can wait, the 175mm posts are coming ... a real donkey dick of a post ... I reckon it will be overkill for you personally *shrugs but I'd measure max insert depth on your frame vs post height at full extension and we can provide dimensions to confirm if suitable ... if you are in the Cairns area have a chat with Vincent at Edge Cycleworks there is a 175mm demo floating around up there.
I personally recommend LEV DX 150mm with southpaw as best bang for buck.
We lowered KS pricing recently so worth talking to your fav store if you like supporting Australian jobs.:hippie:
