WONG the problem is that chain rings are not designed to used unless they line up correctly with the receiving recesses on the spider. Only running 2 chain ring bolts would have them missing this recess.Well there is the problem, your chain is upsidedown (sp?)
hehe thats what i told him. maybe he ill learn now after his second pair of cranksThat's what you get for running MTB cranks and chainring
There's nothing quite like feeling sea sick from bent mtb cranks is there?That's what you get for running MTB cranks and chainring
Learn to spellcheck.WONG
no thats write hes wongLearn to spellcheck.
Yes I know that running your chain unpsidedown would not have broken the sprocket, I was merely pointing out that it was on backwards.WONG the problem is that chain rings are not designed to used unless they line up correctly with the receiving recesses on the spider. Only running 2 chain ring bolts would have them missing this recess.
Also with the way that he has single speeded his stp with a half link chain wouldnt be so bad if he used a single speed tensioner with the little jockey wheel. There would have been mega pressure on the chain ring and i bet his chainline was buggered also.
WONG.
That's just wong, right?no thats write hes wong
