Hey Guys
Just doing some maintenance on the bike whilst I am laid up.
I replaced the shift cable, BB and re-greased the jockey wheels.
I have an odd problem, In the largest cog right through to second from bottom everything is normal, up shifts/ downshifts runs smoothly and when you back pedal the bike just free spins as normal.
In the top two gears (smallest cogs) as soon as you back pedal the cassette picks up a link and up shift the the next largest gear.
I have had a look at cable tension, checked the Dropout alignment, and adjusted the limiter screw. It weird.
I re assembled the Crank with all the same bits in all the same order. And then re assembled with an extra spacer on the drive side. This has made it better. but its still there.
Has anybody else come across this.
Duckmiester?????? HELP :noidea:
