Racing Ralph are currently available in 4 basic flavours for 26", Evo, Snakeskin, Tubeless(UST) and Double-Defence. (weight given for 26x2.25)
Evo are the lightest with very thin sidewalls for minimum weight so greatest risk of sidewall tear. (520g)
Tubeless add the UST compatible bead to seal against UST rims, the sidewalls are reinforced with the intent to support the bead, not specifically to avoid sidewall tears. (710g)
Snakeskin has additional material across the entire carcass to resist scrubbing, ie. sidewall damage. (570g)
Double-Defence has the same additional material as the snakeskin as well as some proprietary Vectran fibres woven through the tyre to also avoid piercing damage. (610g)
Rocket Rons are not available in Snakeskin or Double-Defence.
So snakeskin seems like a reasonable compromise at only 10% heavier than the evo and without the un-wanted weight of the UST bead which makes the tubelss 40% heavier than the evo. As I run Stan's sealant anyway, I don't have problems with piercing damage from thorns etc.
The Racing Ralph is nice in that the range offers more options than just either UST or ultra-thin sidewalls.
