FoxRidersCo
Sanity is not statistical
2011 Fox 36 180mm
Damper - FIT
Stanchions - NEW Kashima Coat
2011 Fox 36 160 Talas
- NEW FIT RLC 160
Damper
- FIT
Stanchions
- NEW Kashima Coat
Weight (1 1/8" steerer)
- 4.67 lbs / 2.12 kg
Weight (1.5" steerer)
- 4.65 lbs / 2.11 kg
Travel
- 6.3 inches / 160 mm
External Adjustments
- Low-speed compression
- Lock force out
- Air spring pressure
- Rebound
- Talus 2 Position travel is adjustable down to 120mm in 10mm increments
Lower Leg
- 20QR thru axle system, Post style disc brake mounting
Color
- Black Diamond
Spring
- Air
2011 Fox 40
- NEW FIT RC2
Damper
- FIT
Stanchions
- NEW Kashima Coat
- 6.81 lbs / 3.09 kg
Travel
- 8 inches / 203 mm
- High-speed compression
- Coil spring preload
- Rebound
Internal Adjustments
- Hydraulic bottom-out resistance in damper
- Travel is adjustable down to 6.5 inches in half-inch increments
Lower Leg
- 20 mm thru axle system, International Standard disc brake tabs
Color
- Black Diamond
- White
Spring
- Titanium Spring
Damper - FIT
Weight (1 1/8" steerer) - 5.22 lbs / 2.37 kg
Weight (1.5" steerer) - 5.18 lbs / 2.35 kg
Travel:- 7.1 inches / 180 mm
External Adjustments:
- Low-speed High-speed compression
- Rebound
- Talas 2 Position travel is adjustable down to 100mm in 10mm increments
Lower Leg: - 20QR thru axle system, Post style disc brake mounting
Color - White
Spring - Air
- Rebound
Color - White
Spring - Air
- NEW FIT RLC 160
Damper
- FIT
Stanchions
- NEW Kashima Coat
Travel
- Lock force out
- Rebound
Lower Leg
Color
- Black Diamond
Spring
- Air
2011 Fox 40
- NEW FIT RC2
Damper
- FIT
Stanchions
- NEW Kashima Coat
Travel
- 8 inches / 203 mm
- Rebound
Lower Leg
Color
- Black Diamond
- White
Spring
- Titanium Spring
