Formula Brakes 2012
2012 Formula RO (Replaces the One in the product line) supposed 15% more power.
Radial Master Cylinder /
Oval Piston. Weight - 337g
Above statement is not quite correct. May I make a correction. In fact I'll give you a quick run down of the Formula range for 2012!
The RO not only has more braking power (approx 15%), but the main advantage of the RO is that the larger piston surface area actually results in improved modulation - that's the goal of the RO, improved modulation. The RO is available in a polish with black FCS and TFRA only.
The new RO is the new DH brake. The first brake with Oval pistons, giving an huge effective diameter of 25.4mm.
The Formula TheOne remains in the line up of brakes but takes in the position as the perfect "all-rounder". For 2012 TheOne has the TFRA (Tool Free Reach Adjust) and FCS (Feeling Control System) added - these are no longer optional upgrades on The One. TheOne remains black with gold caliper piston cover and gold FCS and gold TFRA. Weight with these features is now 336g including mounting hardware and 160mm rotor.
The R1 has received the addition of the TFRA for 2012 as standard. The R1 now weighs 298g including 160mm rotor and hardware and comes in a glossy black finish rith red TFRA and caliper piston cover.
Added to the lineup of Formula brakes is the R1Racing or R1R. This brake is kept minimalistic with no additional adjusters, but instead with a carbon lever blade and complete Ti hardware and alloy backed pads as standard - polished finish. At 270g it remains the lightest production disc brake on the market.
The RX remains the best value brake. It comes standard without the TFRA and FCS, but both can be upgraded as previously. For 2012 the RX is available in a white or black - both with a red caliper piston cover.
-The main goal for 2012, other than to introduce the R0, was to bring in all features that were optional in 2011 and have them as standard where relevant.
-The MC body has been optimized and the reservoir has increased for all brakes for 2012 as well as the small torx bolts that annoyed so many people replaced by hex key bolts.
-The IRA (Instant reach Adjust) has been redesigned and is now integrated in the lever.
-The FCS's outer contour has been changed to be more "skin friendly".
That was a quick run down for Formula Brakes products for 2012! Enjoy...
