hifiandmtb
Sphincter beanie
Good luck trying to find a new Conti X-King 2.4" tyre. Fuckers don't seem to be made any more.
My go-to tyre on the Tallboy
Pic didn't upload ?So I managed to crack the rear carbon rim at Stromlo on the weekend and have switched back to my Crest MK3 rear wheel with non-boost Tune hub. To be perfectly honest, I probably can't tell the bloody difference. I think the Crest MK3 rear wheel gives a smoother ride which translates to more traction in pea gravel over hardpack. Certainly can't feel the difference in weight or boost/non-boost.
Here's a close-up of the rim failure. You can see that it hasn't been caused by a rock strike. The bead is un-marked, it's just experienced a bit too much force for the layup and the inside rim bed has detached from the outside layers.
Fine here...Pic didn't upload ?
You have outlined a pretty solid case for my dilemma, I think I'll just get another Crest rim instead of going carbon...
Could you limp it back to the car park or did you have to call it a day?
...Could you limp it back to the car park or did you have to call it a day?
Should have shortened the chain and single speeded it, it's not that badFunny story actually. My XTR RD had broken just after Double Dissolution so I had to remove my chain and freddy flintstone it back to the pavillion. I came to the top of the Luge and then descended chainless and broke the rim near the bottom.
As I knew the rim was cactus I rode on it down to the pavillion and put a tube in it. The buckle was huge but it just cleared the chain stays. Rode to a mates place near stromlo to see if I could borrow a rear derailleur to get me the 18km home. He wasn't home so I basically had to scooter it. Got about 6km from home when a mate picked me up.
Normally a good option but the chain growth on the Trance makes this a bit of a non option. I did that once on my Anthem and by the time I got back home from Strommers I'd cracked my Tune freehub which proved to be another expensive exercise. Maybe if the shock had a very firm lockout with no blowoff then you could get away with it.Should have shortened the chain and single speeded it, it's not that bad![]()
It is annoying that the Crests on the rear only last about a year but until they crack up they are great and the cost of replacement is not so high that it makes me ride like a weenie to avoid trashing a rim.Yeah get Crests. They are bulletproof.
Ha ha I've gotten so used to riding a hardtail I didn't even think of the full squish (unless it's a Roval). I'll see myself outNormally a good option but the chain growth on the Trance makes this a bit of a non option. I did that once on my Anthem and by the time I got back home from Strommers I'd cracked my Tune freehub which proved to be another expensive exercise. Maybe if the shock had a very firm lockout with no blowoff then you could get away with it.
All well & good when you can replace them yourself.I've always viewed rims as just another wear item. So cheap and cheerful for the win.
I've mostly seen Stan's rims cracking through the spoke holes, is it worth adding nipple washers to the next build?It is annoying that the Crests on the rear only last about a year but until they crack up they are great and the cost of replacement is not so high that it makes me ride like a weenie to avoid trashing a rim.
