jathanas
14-16 PSI!! Far out krisko, no wonder they felt a little squirmy.
At 76kg I run 22 front - 25 rear. I own a digital tyre pressure gauge, it helps to really know when you run low pressures...
Cheers, J
Cheers, J
Ok I went out for a couple of hours last night and had alot of trouble with tyre pressures. My usual 28-30psi used on my Rocket Rons, had me bouncing around stromlo like a pinball!
I let out pressure prior to the decent and did the grab the tyre trick, yep it felt as if I was running mid 20psi.... later at home I checked and i was running between 14-16psi!!!
On these pressures I felt the tyre rolling somewhat on longer turns making me nervous.
I think the sidewalls deceive you with the grab test and I'll be trying 20-22psi. What pressures are you guys running? Im 88kg.
