I don't know if this is in the other thread, but it's relevant here anyway.Rockshox Reverb
Weight 535g (1.17 LBS)
Length 380mm / 420mm, 125mm Adjustable Range
Colors Black
Material Shaft: 3D Forged 7050 Alloy, Head: 7050 Forged Alloy
Finish Anodized
Other Zero Offset / 2-Bolt, Reverb Remote Actuation: Adjustable return speed at the handlebar
Available in 30.9mm / 31.6mm Diameters
Rockshox Reverb
Colors Black
Finish Anodized
Excellent fellas. Makes it easier. I'll keep quoting when more join, and start a new thread, maybe a sticky.Crank Brothers Joplin
material aluminum
post length 398mm
weight 590g
adjustment range 100mm / 4in
cable type standard shift cable
diameters available 30.9mm and 31.6mm
warranty 2 years
Also comes in 75mm adjustment.
I, on the other hand, have a different opinion to the author mentioned above (Australia's driving future perhaps?).The Joplin gravity dropper seat posts are rubish.
I cant stress enough how SHIT the Joplin post are.
Thanks mate. The way you are using it sounds exactly like what I want to do.Rod and Grant,
I am running the command post, it is an awesome bit of gear, 125mm of travel and a remote lever that works awesomely well, i havent had to bleed it, clean or anything, it came on my Evo, but it works so well, i was thinking of selling it when i bought the bike thinking i wouldn't use it, but i use the thing non stop, the 3 positions are up for normal pedalling, down one for technical riding, then the 3rd position drops right down for downhill riding, both of you guys know that we do lots of technical riding up here, mt york, Lawson, 6ft track, knapsack etc.
In 6 months ownership i have not had to touch it, it is sealed really well from dirt and dust!
I modified the remote lever by using and xtr v-brake elbow and xtr cable, works beautifully, pm me if you want any more info!
Yeah it has surprised me a great deal, i know you love your technical riding, and it would suit you down to the ground, i think going for a really reliable product is the way to go, also i think it's a must to have handlebar remote, you dont want to be taking your hands off the bar at anytime, sometimes you have a very short amount of time to activate it, and hands on is the only way, i have used it in several races at yellowmundee when you dont have much time between topping out on a climb before dropping the post immediately to do techy type descents!Thanks mate. The way you are using it sounds exactly like what I want to do.
