Ok slightly off topic. Bought this for the little one. It's 8.4kg which is ok compared to most bikes out there like this. Needed some work so I go at it. Man everything is so heavy on there!
Bar and stem combo is pushing a kilo. The fork looks like it's solid steel. The brake lever is obviously not made for kid, the reach is munted and the handle grip required is a fair bit.
Ok so here is the thing I ride bikes, I spend a fair bit on them. It's not really fair if my kid ride a junker (well I paid $50 for it) but whos counting? If you scale the weight up it would be like me riding a 38kg bicycle which is nuts. So the aim is to drop a few kilos. That's where aliexpress comes in.
Fork (-500g): Still questioning if I do this or keep the caliper brakes. It will be a massive weight drop and I don't think there will be structural issues with chinese carbon for a kids bike loaded the way they are. THe main point though is this one is disc
https://www.aliexpress.com/item/32849118718.html?spm=a2g0o.productlist.main.35.63b1ileiilei64&algo_pvid=c9349fec-40b0-400f-9134-0647f56c6e59&algo_exp_id=c9349fec-40b0-400f-9134-0647f56c6e59-17&pdp_npi=4@dis!AUD!62.75!62.75!!!296.96!296.96!@2103201917172431705062295ea24b!65202546726!sea!AU!4371160902!&curPageLogUid=PZ7pBohdh2pF&utparam-url=scene:search|query_from:. Still questioning if I do this or keep the caliper brakes.
Bar (-500g): Still undecided if I should stay the smaller clamp size or not, but this is mighty juicy at $30 a pop.
Smarter Shopping, Better Living! Aliexpress.com
www.aliexpress.com
Stem:
https://www.aliexpress.com/item/1005006079890603.html?spm=a2g0o.detail.pcDetailTopMoreOtherSeller.11.2a6eHKVHHKVHhF&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40000.327270.0&scm_id=1007.40000.327270.0&scm-url=1007.40000.327270.0&pvid=90042cb0-11b4-4e91-957a-433c9330cac7&_t=gps-id
cDetailTopMoreOtherSeller,scm-url:1007.40000.327270.0,pvid:90042cb0-11b4-4e91-957a-433c9330cac7,tpp_buckets:668#2846#8110#1995&pdp_npi=4@dis!AUD!12.50!11.80!!!59.15!55.82!@2101c5c217172456506796092e4750!12000035643992420!rec!AU!4371160902!&utparam-url=scene
cDetailTopMoreOtherSeller|query_from:
Grips:
https://www.aliexpress.com/item/1005006148813758.html?spm=a2g0o.detail.pcDetailTopMoreOtherSeller.1.209b2ote2otek1&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40000.327270.0&scm_id=1007.40000.327270.0&scm-url=1007.40000.327270.0&pvid=a78ba7e0-ffc2-4fa9-ade9-539975223702&_t=gps-id
cDetailTopMoreOtherSeller,scm-url:1007.40000.327270.0,pvid:a78ba7e0-ffc2-4fa9-ade9-539975223702,tpp_buckets:668#2846#8110#1995&pdp_npi=4@dis!AUD!5.43!2.28!!!25.72!10.80!@2101c5c217172451965238259e4750!12000035980785749!rec!AU!4371160902!&utparam-url=scene
Tassels:
https://www.aliexpress.com/item/1005006489038554.html?spm=a2g0o.detail.pcDetailTopMoreOtherSeller.12.2612kap9kap9Ul&gps-id=pcDetailTopMoreOtherSeller&scm=1007.40000.327270.0&scm_id=1007.40000.327270.0&scm-url=1007.40000.327270.0&pvid=996cab83-fa3a-4401-b49b-683508b4856c&_t=gps-id
cDetailTopMoreOtherSeller,scm-url:1007.40000.327270.0,pvid:996cab83-fa3a-4401-b49b-683508b4856c,tpp_buckets:668#2846#8110#1995&pdp_npi=4@dis!AUD!2.56!2.56!!!12.12!12.12!@2101c5c217172452234718743e4750!12000037391844759!rec!AU!4371160902!&utparam-url=scene
Front disc wheel: Struggling to find anything on aliexpress or anywhere else really. The ones on ali appear to be build more tankish than what I have and the disc ones I found are solid mags for moto! I think my ali searh skills are lacking here.
Brake: Some old M675 levers beacuse they are the only ones I have with reach adjust that's in storage. Put some RT800 rotors on there because they are one of the few without holes for little people to poke fingers through.
Cranks: I also don't know the standard of this crank so will search around for lighter replacements.
Chain/ Chainguard. Plan is to ultimately remove the chain guard and hot wax dip this sucker. Correct me if i'm wrong but I would think the issue is kids touching the grease, not neccessarily them sticking a hand in there? But kids are dumb?
Post; Seems ok, it's some strange 25mm size (1 inch) but integrated with the saddle. Saddle looks heavy but being integrated means it's probably all together not that heavy.
Target weight, 7kg flat
Am I mad?
