I’ve found a Novatec qr hub with xd on Aliexpress for not much more than the ztto hub, so the build your own option is getting more tempting. Would just need to wait for the hub to turn up and then order spokes locally.Ah, QR front needed too? Dang, probably not convertible
There will be an online spoke calculator if you know model, and rim.I’ve found a Novatec qr hub with xd on Aliexpress for not much more than the ztto hub, so the build your own option is getting more tempting. Would just need to wait for the hub to turn up and then order spokes locally.
Adaptable maybe?Ah, QR front needed too? Dang, probably not convertible
Novatec would be perfectly fine for a commuter.I’ve found a Novatec qr hub with xd on Aliexpress for not much more than the ztto hub, so the build your own option is getting more tempting. Would just need to wait for the hub to turn up and then order spokes locally.
I used these on my boys bikes before forks went 110mm boost, they worked flawlessly on a 15mm thru axle fork when running QR wheels.Adaptable maybe?
15mm To 9mm Hru Axle Adapter Thru Axle Hub Bicycle Converter QR Adapter | eBay
Find many great new & used options and get the best deals for 15mm To 9mm Hru Axle Adapter Thru Axle Hub Bicycle Converter QR Adapter at the best online prices at eBay!www.ebay.com.au
The one I’m looking at is D792SB.Adaptable maybe?
Which model hub is it? I've built a couple of wheels with Novatec hubs and have a notebook with dimensions (flange diameter, locknut to flange, etc). The online calculators don't always have Novatec listed, not since I last looked anyway.
I usually plug in the numbers manually here:
Thanks for that. I was able to get the measurements no problem and get the details I need.Damn, just looked at my notebook and I've only built a D882SB rear.
If you can decipher the explosion diagram here, you could use the dimensions in the aforementioned spoke calculator link.
Looks very much like a Hope copy.Anyone given hubs a go? I’m wanting an xd wheel to go a 9-42 ztto cassette and spotted these: https://www.aliexpress.com/item/100...o.store_pc_groupList.8148356.8.75d02b57AdmHGL
Probably made in the same Chinese factory!Looks very much like a Hope copy.
Well you can’t not include the URL for them!
So light even the scales are smiling.Built up scarily light for a dubious quality, 35mm wide rim.
You seem to be missing some spokes though...Built up scarily light for a dubious quality, 35mm wide rim.
here ya go - https://www.aliexpress.com/item/1005001443452592.html?spm=a2g0s.9042311.0.0.28764c4dnQdfAjWell you can’t not include the URL for them!
Interesting, the prices are cheaper on Ali vs buying direct from their website:here ya go - https://www.aliexpress.com/item/1005001443452592.html?spm=a2g0s.9042311.0.0.28764c4dnQdfAj
edit- actually this one https://www.aliexpress.com/item/4000285080553.html?spm=a2g0o.detail.1000060.1.2db11894tGbqTP&gps-id=pcDetailBottomMoreThisSeller&scm=1007.13339.169870.0&scm_id=1007.13339.169870.0&scm-url=1007.13339.169870.0&pvid=b0d46728-8632-4153-8a42-a4103d72a58a&_t=gps-idcDetailBottomMoreThisSeller,scm-url:1007.13339.169870.0,pvid:b0d46728-8632-4153-8a42-a4103d72a58a,tpp_buckets:668#2846#8115#2000&&pdp_ext_f={"sku_id":"10000001177863942","sceneId":"3339"}
