Not sure what you mean by noisey, presume thats with the cane creeks and the gimble rattling around or something. For the K9 Angle Reducer Cups (ARC) ... they are just like the usual semi integrated Cups found on all headsets ... so there won't be any rattle or noise with these, when installed correctly. Note: you need an IS compatible headset (specifically the 36 x 45 deg bearings, headset dust cover and races) ... Also come in a frustum (z44/56 top and bottom cups respectively).Mixed results from reviews ive found so far with "noisey" being the common complaint.
you need to know the cup sizes of the tapered head tube if its a 44/56 cup then we can help with a K9 2deg ARC.I'd love to slacken my 2010 reign out a little, can it be done?
Did I mention ...
"K9 ... the original and the best" ...irate:
set and forget :decision:
MBAction tested two bikes in this month's issue with the Cane Creek AngleSet (Niner RIP9 & Pivot Firebird) - both bike suffered from "a popping noise under hard braking and when hitting flat-edged surfaces". They disassembled, re-greased & reinstalled on both bikes but the problem returned.
Take from this what you will, but adding complication at the headset will likely cause issues over time. That component goes through a lot of stress.
Frustum (Tapered) ARCs are RRP $125 ... straight tube ARC are RRP $115 ... see the Pushie Thread for more details ... http://www.rotorburn.com/forums/showthread.php?228865-Introducing-Pushie or head to our facebook pagehmm how much as the cane creek ones are super pricey
just to confirm from our conversation the remedy is a 56mm bottom therefore K9 have a 4.5" & 5.1" length in a 2deg angle change.Will the k9 fit a remedy though? I've checked their site but doesn't really have that much info..
