MARKL
Yeah there is one other factor. Bonding.
For carbon frames an alloy BB must be bonded into the frame in no high stress area. This has shown quite a few failures in the past which is a complete frame warranty (getting cracks around the BSA insert). So manufacturers (in addition to your points above) have moved towards pressfit . Generally, they won't warrant a frame for a creak so for the manufacturer, the possible failure is a no cost to them compared to bonding a shell in, which is now their problem.
Anyways, they shouldn't creak, and of they do, they should be fixable, but mechanics and owners either do t know how or won't (eg strong hold locktite or epoxy)
The biggest advantage Pharma pointed out is manufacturers won't warrant your frame when it creaks...winning! Unless you like a frame that creaks, then awesome :frusty: They are a shit standard, especially press fit.and the fact that no bike manufacture dares to tap threads into a carbon frame? for very good reasons. So if a manufacturer really wanted a threaded bb they go for the heavier option of inserting metal threads but as pharma pointed out is inferior straight away to press fit.
Try some reading...http://www.pinkbike.com/news/to-the-point-bottom-brackets-2014.html
http://www.bikeradar.com/au/gear/article/complete-guide-to-bottom-brackets-36660/
