GDonehue
So I have been in the market for a new bike for some time now. I test rode a bunch, liked a few, hated a couple and loved two. So how did I end up with a bike that even I admit makes me puke a little when I look at it? It all came down to the test ride and bang for buck. I picked it up cheap - in fact so cheap if I end up giving in to the optically induced nausea and decide to buy another frame I probably still end up in front...
I test rode the EX8 earlier in the year and it was just insanely fun. I don't tend to do shuttles anymore, so something with the ability to ride up and smash down was on the cards. I have previously owned a Canfield One and this bike pedals better and had more stability coming down.
Is it really ugly? Yes. But then realistically, if I park it in the same spot at home I can close my eyes when I walk up to it and all I will see is the top tube, which is not that ugly at all. Instead I will make others puke as I ride past them and I kind of like that.
It arrived only 20 minutes before I had to ride to work - so no full pictures of the beast until it gets built tomorrow
Frame - POLYGON XSQARONE EX9, NAILD R3ACT 2PLAY SUSPENSION ACX, 180MM TRAVEL, BOOST
Rear shock - FOX FACTORY FLOAT X2, E2E 230MM X 65MM, 180mm Travel
Front shock/fork - FOX FACTORY 36 FLOAT, 180MM TRAVEL, BOOST FIT4 3-POS LEVER W/ ADJUSTER,
Handlebars - RACE FACE NEXT R 35, CARBON W-780MM R-20MM
Stem - RACE FACE TURBINE R, ALLOY E-50MM R-0DEGREE
Headset - FSA ORBIT C-40/48-CF-ACB
Grips - Not sure - I did not get the chance to unwrap the bars yet - but I bet they are UGLY
Saddle - ENTITY ASSAULT W/ CRMO RAIL
Seatpost - KS LEV SIO, TRAVEL 150MM
Front brake - SRAM GUIDE ULTIMATE
Rear brake - SRAM GUIDE ULTIMATE
Cranks - SRAM XX1 EAGLE 12-SPEED 32T NARROW-WIDE BOOST,175MM
Chainguide -
Bottom Bracket -
Chain - SRAM XX1 EAGLE 12-SPEED
Pedals - CRANK BROTHERS MALLET E
Rear derailleur - SRAM XX1 EAGLE 12-SPEED
Rear shifter - SRAM XX1 EAGLE 12-SPEED
Cassette - SRAM XG 1295 EAGLE 12-SPEED 10-50T
Wheelset - E13 TRS R CARBON BOOST
Tyres - SCHWALBE NOBBY NIC, 27.5”X2.60”
Total weight - Not sure - 13Kg something if my bicep curl out of the box was correct
Chainguide -
Bottom Bracket -
