That is because an almanac was already in your phone.I've done plenty of rides with my phone in flight mode and not had an issue with tracking.
What exactly is that?That is because an almanac was already in your phone.
The GPS almanac is a data set that every GPS satellite transmits. It includes information about the state of the entire GPS satellite constellation, as well as coarse data on every satellite in orbit. The orbital position of each satellite is known as the ephemeris data. While the ephemeris data helps deliver more precise locations to GPS devices, the almanac data helps the device locate a region of eligible satellites. This information is then saved for faster signal location in the future.What exactly is that?
Phones can use both the almanac received by your data connection (on mobile network) for faster GPS fix or in places with no network coverage, can use the almanac provided by the satellites themselves.The GPS almanac is a data set that every GPS satellite transmits. It includes information about the state of the entire GPS satellite constellation, as well as coarse data on every satellite in orbit. The orbital position of each satellite is known as the ephemeris data. While the ephemeris data helps deliver more precise locations to GPS devices, the almanac data helps the device locate a region of eligible satellites. This information is then saved for faster signal location in the future.
The GPS almanac also includes clock calibration data as well as information for correcting distortions caused by changes in the ionosphere. When a GPS receiver has current almanac data in memory, it can acquire satellite signals and quickly determine an initial position.
Thanks for rehashing what I said earlier.Phones can use both the almanac received by your data connection (on mobile network) for faster GPS fix or in places with no network coverage, can use the almanac provided by the satellites themselves.
Your phone uses assisted GPS (aGPS). If the phone does not have the almanac and you don't have reception, it takes a about 15 minutes to download the almanac from the satellites.
If your phone has previously downloaded the almanac it should find its location quickly.
So it depends
Yep, or the phone got the almanac using GPS, thus your phone does not need a data connection to track your ride on Strava which is the whole point of this discussion. Sorry, I didnt read every post, mainly just the ones I was quoted in so based my comment on you saying the above.That is because an almanac was already in your phone.
Yet you keep rehashing what I have already said, even when you are quoted.Yep, or the phone got the almanac using GPS, thus your phone does not need a data connection to track your ride on Strava which is the whole point of this discussion. Sorry, I didnt read every post, mainly just the ones I was quoted in so based my comment on you saying the above.
Onya Champ.Yet you keep rehashing what I have already said, even when you are quoted.
