WolfCreekPsycho
I would have thought there would also be an addtional force not in your picture.... i have added the Yellow and Blue arrows.
Using the rear wheel to stop the bike (halt momentum) means that the rider and rest of the bike will want to keep moving forward. However that cannot take place as the bike and rider are all attached to the rear wheel and swing arm. What can happen is that the force of rider and front of bike will try to actuate on the pivot point between the rider and the item doing the braking, causeing force through the swingarm pivot. You have another pivot point in this equation and that is the front wheel on the ground. When you apply the rear brake it attempts to turn the frame holding the rear wheel in the same direction as the tyre is rotating ie towards the ground (shown by blue arrow). As the front wheel on the ground prevents the swingarm and frame from rotating around it has to put that force through the swingarm linkage causing it to flex.
Just my 2 cents in a great thead
