Maybe I should have started a new thread so you could all tell me to use the search function![]()
We have to haze the newbies somehow...
So to be "fully active..." you need three things?
-Two of the links which are perfectly parallel with one another all throughout the travel.
-a CC which is fixed with respect to at least on of the pivots.
-an IC distance which is infinitely far away (in front or in back of the axle).
If by "fully active" you mean no brake input to the suspension whatsoever, you'd need two parallel links (which give you the infinitely far away IC) and a vertical axle path. But that's assuming you want no brake input to the suspension...
Lets say you knew the average IC distance of every downhill bike evermade. Could you ordinally rank them in order of BISI using their respective (avg) IC distance from longest to shortest.
Does such a bike exist; or whats closest to it?
