Binaural
That explains why the flight stewards on my last trip to China were such huge dicks then.If only I could get on a plane and have it affect my wang with out expanding the rest of me
and why Virgin stewardesses all have such voluptuous breasts.That explains why the flight stewards on my last trip to China were such huge dicks then.
You could try a metal insert,then you could start calling it a rod ,But if the flight gets turned back that will be double downsizing,this is a big risk that we cannot afford to take.If only I could get on a plane and have it affect my wang with out expanding the rest of me
Bahahahaha... GOLD!! I love it.You are wrong. Different shaft diameter, different thread, different in hex.
although if you get one and send it by plane...
Not to mention bar height, stem length, chainstay length, chain link length, hub width, seat tube size, bottom bracket configuration, headtube size, and that's not even taking into consideration the size of tubing!yes. the flight could have a major effect. you should check your top tube length. i bet you wanted 20.75" top tube but now your frame is 21.5". you won't get warranty. this is why you should support you lbs.
Not such a crazy theory. Notice how the development of the mountain bike coincides with the dates people started shipping via air. Coincidence? I think not.Not to mention bar height, stem length, chainstay length, chain link length, hub width, seat tube size, bottom bracket configuration, headtube size, and that's not even taking into consideration the size of tubing!
Hell, if you've got relatives all around the world sending you your new rig via different processes you'll ask for a BMX, 20.75" toptube with 8" rise bars and find you'll end up with a fully geared DH Comp with 2.7" tires!
And you think the BOLTS are the most of your worries!
I agree...NCR600 said:Best thread ever.
With you, I understand this is ALWAYS very short lived.but the effects are never permanent. They're very short lived.
Yep,If only I could get on a plane and have it affect my wang with out expanding the rest of me
That's what I'm saying. Short is the story of my lifeWith you, I understand this is ALWAYS very short lived.
And I find as I get older it gets worse.That's what I'm saying. Short is the story of my life
Have you tried wrapping your wang in foil??If only I could get on a plane and have it affect my wang with out expanding the rest of me
Hence, miles instead of kilometers, lbs instead of kilos and ounces instead of ml...The reason for this is that Americans are retarded and cannot accept change in even the simplest or most logical form.
