Hey guys,
Boy do we have some exciting news from the guys at DEITY for 2008!
Eric Davies has a lot of new products in their lineup for 2008. The focus seems to be on improving on a lot of their products in terms of usability and lighter weight. All products will be available starting January 1st, and the new Vendetta crankset will be available as a special order item as soon as November.
Vendetta Crankset. Eric and Sadie have hit the jackpot possibly on this new crankset. They’re incredibly light. I weighed a set of these new cranks with all of the bottom bracket hardware (for 73mm and steel axle) and it came in at a scant 961g on the Ultimate hanging scale. If you know 3 piece cranks this is quite the feat. A Saint/OCT setup comparable is ~930g. Details below.
- A lot lighter
- Self Extracting bolts
- 7075 bottom bracket (sleeve, cups, spacers)
- Lower profile / box cut
- 73mm or 83mm bb kits
- Titanium Axle’s direct from Deity (full hollow)
- 170mm in November
- Increased clearance to reduce any chance to ankle banging on the arms
- 1 piece sprocket boss with micro-dirve bearings (can run down to 22t)
- Hollow crank bolts
- No hammer necessary for installations or removal
- HRCS graphics etched into the powder coat with a clear coat on the outside
- More durable
- Same retail price.
- Special release Nov
DIRTY 30 DEITY bars.
- 30” bar
- 1" rise (25.4mm)
- Dbl butted 7075
- HRCS graphics
- New finish
- Gray / black / white
- Lightweight approx:260gr
- 25t or 28t
- 7075
- 6 points of engagement so you can rotate this sprocket to increase its life
- White, gray, or black anodize with lazer graphics.
- HRCS Graphics
- Lightweight
REVOLUTION 4b DH chainring
- Features a more cutout design
- Direct bashguard compatible out of the box
- Thicker sprocket
- 7075
- Chamfered edge
- Recessed mounts to improve clearance
- Sprocket boss bolts
- 4 bolt sprocket positions to increase life and wear
- 8 and 9 Speed compatible
JUMP series saddles
- Lighter
- Hollow 8mm cromo rails
- 3 styles
- Low profile rails to reduce weight and reduce rails bending
TIBIA seatpost
- 27.2mm
- Same guts as shadow conspiracy and other bmx companies
- Forged out of 2014
- w/4 7075 shims to accommodate other sizes
- two graphics, single bolt spring loaded
- lots of angle adjustability
- 8mm seat rails
- 350mm length
Chocker seatpost clamp
- 31.8 / 24.9
- White powder or black anodize
- 2014
Fantom Stem
remodeled and lighter design stem- Cutout 6061
- Rearward clamp
- Reverse blots
- Machine windows
- Cross member machining
- Pockets in faceplate to reduce weight
- Very low stack (35mm, old 31.8 was 50)
- 7075 end caps
- Odi compatible
- Grub screws recessed for long term use.
- Double set screw design
If you feel like checking out all the new products through a video hosted by our mate Eric davies click on the following link:
http://www.pinkbike.com/video/671/
All products listed above will be available Jan 1st. Deity has maintained the price structure they’ve always had but with a huge emphasis on lighter weight as well as including new parts. Check out the details below. There’s not enough room on this page to even begin to describe all the updates they’ve done. Definitely more race-inspired goodies.
In Spring 08, Deity has got a few ideas to wet your tounge
- Direct mount stem
- 1.5” stem
- Single speed conversions “Street sweeper” 11t through 14t
- Hollow Ti DH saddles (3 graphics)
- LE color
We expect a huge response from the DIRTY 30 bars and are trying to make sure we have some for everybody. So start backordering now through your local bike shop to secure a set today!
Remember you can find all this information on www.rouler.com.au
you can email us at rouler@rouler.com.au or contact us by phone on 0402 138 508.
We look forward to hear from you. Thanks for your support!
Nicho
Courtesy of Deity and sicklines for the photos and details.
