Yeah, still haven't done the mods to mine yet, just to keep everyone updated.
Turns out you need a specialist tool to take the bottom bolts out of the forks, a marzocchi-only-super-narrow-socket-fitting for fuck sake. No they couldnt just put a normal allen head bolt in there, or even a normal bolt that you could access with a normal socket, they have to put a goddamn recessed bolt that fits in the fork with such tight tolerances you need a specialist tool to access it.
MARZOCCHI! READ THIS AND KNOW THAT YOU ARE ALL ARSECLOWNS!
*EDIT* - I did however manage to change the stock oil out for some 12ish weight (my LBS' 'secret pro blend' apparently) oil and the improvement is massive, I highly reccommend doing this if the forks are bit pogo-ish as it improves the rebound dampening out of sight.
