-It can be set so the guys running one or two chainrings can have the front drop to the lower ring / rings depending on what gear you grab on your cassette. Of course this can be customised and can be set to run manually. My understanding is it can also control the front and rear deraileurs on one shifter!
You mean two or three rings.... :wink: Synchro shift means that at certain programmed (factory default, but user-adjustable via PC interface) points through the shift sequence, rather than picking the next sprocket on the cassette, the system changes chainring and simultaneously makes a corrective "backshift" at the rear to reduce the gear jump. It's switchable on the fly between manual and two Synchro sequences.
-The system battery can be stored on the bottle cage bolts, slipped inside a seatpost or just cable tied to anywhere where it integrates with the cabling of the system. Here's hoping it can go in a steerer and have a charging port made for easy access.
There's a charging/"E-Tube" software connection port on the head unit. PRO (Shimano's offshoot components manufacturer) has simultaneously released Di2-ready cockpit hardware which allows steerer tube battery mounting. They're onto you already. :wink:
-It will likely have integration with Fox technology so you can change the fork and shock settings (ie CTD) and it will show on the HUD. That's tops!
Fox iCD was co-developed with Shimano on the Di2 platform. There's a climb/descend mode icon on the HUD screen. Synchro shift setup allows the left shifter to be used as a suspension switch. What I'm not sure about yet, and would like to know, is if fork & shock can be locked/unlocked independently. There are mixed reports on this with iCD as a stand-alone system, and nothing that I've found yet as far as full Di2 integration.
-Word on the street is it may even have potential to be a GPS and could run maps etc on a big enough display.
Closest I've heard on this front is that there's a plug-in ANT+ digi-box thing that will send gear position indication and maybe a few other things to compatible computers that PRO, Garmin & others have in the works. More road-targetted, 'cos there's no onboard indication there, but there is on the XTR head.
Two things bother me though; what the flipping hell would the system do if the battery expired and the cable tension was non existent? You'd be in the gear it went flat in? Surely a manual system will be implemented, thus making the entire system nothing more than a run of the mill current day shifting system? Why would we go for an electronic system when we still have rear deraileurs getting torn off and bent and making the whole show go arse up?
You end up with a single-speed, like you do when you break a mechanical cable. Front shifting dies first, due to the higher power load, then you lose the rear. But with an indicator right under your nose on the head display, you've gotta be pretty dumb to not notice if the battery needs a feed. There is a degree of crash protection built into the rear derailleur. Under sufficient force, the servo disengages from the derailleur body, allowing the derailleur to get pushed freely on its pivots. There's a restore function by way of holding a button on the head for a few seconds to reconnect the servo. It's not a complete failsafe, 'cos there are multiple ways to hit a derailleur, but it's a help.
