whitey89
Im using a garmin premium heart rate monitor and a 510. Im pretty sure its out because i manually took my resting heart rate at 65bpm this morning.No that doesn't sound right. Given the hearts safe maximum is 220. There are conditions where people have very high like reaching 300 but they are not standing and more than likely laying in a hospital bed and they clearly have serious symptoms.
Even if you are cadel fit you shouldn't be exceeding 220 or even hitting 220 from my understanding.
What monitor do you use? If it is polar they can get interference from other devices and even overhead wires. If your heart indeed reached these numbers I'd be seeing a cardiologist for at least a exercise stress test before I even get back on the bike or do any exercise.
Its pretty unlike for your heart to do those numbers and you still feel fine to ride it sound more likely its a monitor issue or interference. But as this is your heart and this is a forum that you use at your own risk.
It would be my recommendation to go see a doctor ASAP before under taking anymore exercise.
(Many others will say its just the monitor and chances are it is but we are not doctors or have seen you so we cannot know for sure therefore I think seeing a doctor is the only advice I can give you to be safe)
Ill have a look at what could be throwing it out, when i put the strap on it reads anywhere between 85-100 for my resting so it must be out!!! Ill have a play around today and see if I can get to the bottom of it
