Knuckles
Lives under a bridge
While I agree with you, you do realise that any government footing a bill, involves us footing the bill?Infrastructure Australia, an independent body, set up to be non-political, rated the return on investment to be 49 cents per dollar invested.
You don't fix road congestion by building more roads.
The previous government wouldn't release details on the project because the numbers didn't stack up. And then one of them signed a side letter guaranteeing the project consortium a billion dollars in if the project got canned. So much unethical behavior from the Napthine government it is astounding. There needs to be an avenue for the unelected to get an enquiry up and running into underhanded behavior by politicians. This example is a prime candidate.
Daniel Andrews has done exactly what he said he would do. Uncommon for a politician these days. Other politicians should take note.
As for $680 million down the tubes Ridenparadise, I'd like to know where you got your numbers from?
What I have read is that the money that has been paid to the consortium has been for work done up to the point that the project was stopped. The figure is more like $330 million. The Napthine govt should foot the bill for this.
On the issue of roads reducing congestion, correct, they don't, (unless you are referring to toll roads, which do reduce congestion, on themselves. Just look at eastlink, it's a ghost town) they just force the congestion to other, non arterial byways which are even less able to handle the volume.
Mass transport, while not a magic bullet is the best case scenario, for a number of reasons, not excluding road congestion. A dedicated light rail link, running east/west would do more to reduce commute times than a 6 lane dual carriage way.
The major issue with Melbourne's PT system is its radial design, forcing commuters to travel inbound from a satellite station to a central hub, then switch trains to travel outbound to a second satellite station. Essentially doubling comute distance and time. This worked fine when the population more or less lived in the outlying areas and worked relatively centralised area.
No matter what your excuse, commuting by car is the most inefficient and wasteful mode of transport imaginable, the best solution would be to look at dedicated links running laterally to the current rail design, wether that involves new light rail, priority bus lanes or even dedicated bus only roads, someone needs to do some serious engineering before we whack in another barely used, expensive bandaid.
