digitalhippie
Whoot, whoot! 6" travel Mojo HD3 released!
I've gathered up all the info, pics and reviews so far and posted them to the Ibis area on Google+
https://plus.google.com/u/0/communities/101908075366960918611
The new Mojo HD (HD3 for short) is the third act in the Mojo HD/Mojo HDR trailbike trilogy. Everything is new from the ground-up, notably featuring the latest and greatest refinement of the famed dw-link suspension. Geometry is fully modern: longer, lower and slacker, with 6” of plush rear wheel travel. We’ve built in versatile internal routing and updated the frame design, allowing us to put a water bottle on top of the downtube. We also achieve a drop in weight and pedaling performance on par with the Ripley, so the bike is very fast going up, and scary fast going down.
· 650b (27.5") wheels
· The most advanced version of the dw-link suspension on the planet
· 6” of rear wheel travel
· Weight for the frame and shock, size large, matte finish: 5.9 lbs
· 67 degree head angle with a 150mm fork (66.6º with 160 fork)
· Shock specs: Fox Float CTD Adjust Factory Series with Kashima Coat, 7.875" x 2.25", 175lb boost, med velocity, med rebound, LV can, .92in3 volume spacer,
· Optional shock: Cane Creek DBinline
· ISCG 05 compatible with removable adapter
· Threaded bottom bracket
· Super versatile internal cable routing including internal dropper routing.
· Optional polycarbonate down tube cable guard
· Chain stay length: 16.9"
· 12 x 142mm Maxle rear axle
· 160mm post mount left dropout, carbon fiber
· Tapered Head Tube and Steerer
· Up to 2.4" rear tire depending on brand and height of cornering knobs
· Dual row angular contact bearings on the drive side of the lower link that have less play than standard sealed bearings. Preload adjustment is not necessary. Large 28mm x 15mm x 7mm radial bearings on the non drive side for stiffness and long wear
· Bottom Bracket height 13.4"
· Removable direct mount front derailleur mount for a clean 1X look
http://www.ibiscycles.com/bikes/mojo_hd3/
