Bought a brand new 2016 XM527 mid last year for 60% or so off retail as I had sold my old dually around 8 months prior and was looking that whole time for a new bike.
Since then I have replaced lots.
Original forks sucked, put an extra token in but they still sucked so they went. New secondhand fork had the rebound adjuster so the damper went in for a full rebuild.
e:i system gave me headaches. I knew this could be the Achilles heel of this bike and it was. Battery and charger were dead when I bought it then it’s just played up heaps after they were replaced. Lapierre wouldn’t warrant it if I removed it off the bike and the shop I bought it from is a 5 hour round trip. So I sold it and put a new shock on.
M8000 brakes were the first batch ones which pumped up so they went back for warranty and since sold as they still did it, or at least my brain thought they did.
KS dropper started to sag so it went for warranty and since sold as I was right on the minimum insertion
Came as 2x so that went and a decent under bar dropper lever went on
Rear shock bolt kept coming loose, torqued and loctited as per Lapierre instructions, then went with stronger loctite after it kept doing it.
That’s basically it. Haven’t ridden the new suspension, brakes or dropper yet so will see how it goes.
Overall for a $7k retail bike it’s a POS
Frame - 2016 Lapierre XM527 e:i
Rear shock - 2018 Fox DPX2
Front fork - 2017 Fox Factory 34 140mm
Handlebars - Lapierre
Stem - Lapierre
Grips - Lapierre
Saddle - SDG I think, colour matched which makes all the difference
Seatpost - 160mm Bikeyoke Revive
Brakes - Magura MT Trail Sport with 180mm icetech rotors front and rear.
Cranks - M8000
Chainring - Absolute Black 32t oval
Chain - 11sp
Pedals - M8000
Rear derailleur - M8000
Front shifter - Raceface Turbine 1x dropper lever
Rear shifter - M8000
Cassette - M8000
Wheels - Raceface Aeffect
Tyres - Maxxis Ardent 2.4f/2.2t
Total weight - sub 14kg need to weigh it after changing everything.
Extras - K-Edge garmin mount, orange anodised bits
Looking forward to getting out on it. And yes the current photo is of it dirty but it’s very rarely clean.
Stem - Lapierre
Grips - Lapierre
Cranks - M8000
Chain - 11sp
Pedals - M8000
Cassette - M8000
