Doh... oh well disregard my last post. As I came in through the jaycar.com.au site I didn't even think about it. I wonder what postage is like from the US though, as you should be able to get for under $300 (including postage) based on today's exchange rate.remember to check your currency when using the jaycar site.
www.jaycar.com
search: CAT. NO. ST3366
you'll find it's more like AUD$400
what would people prefer to buy out of the AY-UPs Led or HID Technologies lights? im trying hard but cant decide on one of them... i like the look of both but the ayups look better built. i ride mostly xc / aggressive trail at night and want to be able to go just that little bit faster (currently use 1 5w & 1 15w Halogen)....
thoughts? any other light suggestions? ($450.00 budget).
I've just taken receipt of HIDTech's 07 model of the Lumen8R, and it's bloody fantastic! The 07 model is now a top-notch and professional unit @ 1/2 the cost of other HIDs with similar performance.I've been doing a lot of researching about lights recently. I was initially looking at the trailtech HID http://trailtech.net/helmet_light_kits.html which would have been around $270 landed, however I got to thinking that, while they are certainly bright, the HIDs had a couple of negatives in my view:
1. At each price point you are looking at a single light, where I've been happier with a combo of bar and helmet light with my current (1st gen Luxeon) setup
2. The HID globe can fail / break and replacement is expensive (~$100ea)
3. They mostly use Li-Ion packs. I know they are light, hi energy density etc but the thought of it going nuclear while charging and burning my house down doesn't fill me with enthusiasm.
So I ended up deciding to build up a pair of dual Cree XR-E powered LEDs. Run at 1000mA the XR-E produces approx 180-200 lumen from each emitter.They'll be set up with one pair on a bar mount and the other pair helmet mounted. These will have Ledil square optics in a combo of spot & spread, produce about 400 lumen each pair (a single HID is generally 650 lumen) and run for about 3 hours on an 8AA NiMh pack. They are also absolutely tiny.
What's the relevance to this thread you ask?
Well, it seems there is a middle ground between off the shelf and DYI that might be a good solution for some people- The AY-UP lights use a Luxeon III emitter. This only puts out 65 lumens at 750mA but there is another LED, the Seoul P4 which is the same layout and uses the same optics but which puts out about double the light at 750mA. If you weren't afraid to open those pretty AY-UP housings and do a bit of soldering you could easily have a well finished, waterproof lightset with HID like output (ie 4x 140 lumen) across dual lights for an additional $20-30.
They need their eyes tested!!!Hi Gille,
After talking to some guys who had my lights and also had access to the AY-UPS at a recent night race, they reckon the LED technology doesn't even come close to the depth of vision you get with any HID. So if you are looking at serious xc and aggressive riding you can not go past a HID be it a HIDTechnologies one or someone elses.
"As a standalone light, either bar mounted or on your head, there is no LED
light regardless of price that can compete with Halogen or HID systems." Quoted from Singletrack magazine Dec 2006.
I didn't expect it to be this blunt from the maker of a premium HID :Lupine arguably produce the best lights available and they certainly know how to charge for them.
The Lupine website is now claiming the the HID is Dead. Apparently their Wilma LED lights are now just as bright as their amazing Edison HID.
www.lupine.de/
Lumens are meanless without an idea of the beam profile. The narrower the beam the more lumens will be recorded, but the less useful the light is.From what I've been seeing lately I agree that the LEDs are the way of the future- cheap, durable, compact, easy to 'drive' and with light outputs that are getting very serious.
Just to put it in perspective, you could build a quad LED light using Seoul P4 or Cree XR-E LEDs that would produce over 800 lumens and cost about $200 (that's light, battery, charger but not counting labour). One of these would be 100mm wide and 25mmhigh- perfect as a helmet light. Back it up with a dual or triple on the bars and you'd have daylight!
Fair call.Lumens are meanless without an idea of the beam profile. The narrower the beam the more lumens will be recorded, but the less useful the light is.
That said you've got be very interested and I'm going to have to check this stuff out.
To me the HID looks like it's putting out a fair bit more light. Check out the tree trunks and also the ground at the edges of the frame and you'll see it's much better exposed by the HID. Yes LED lights have (many) advantages, but for raw light output I'm yet to see HIDs beaten. Maybe in the next couple of years .Fair call.
Here's a comparison:
If you look down the road to the trees where it curves, the HID is doing a better job again. Light penetration on long fireroad sections is very important, so if the HID is doing that better it's another reason to go for it.
I agree the HID has a slight but noticeable advantage in these shots. But considering we are comparing an $1100+ HID with an LED that can be matched or easily bettered by a handy DIYer for about $200, I still think betting on LEDs for the future is pretty safe...To me the HID looks like it's putting out a fair bit more light. Check out the tree trunks and also the ground at the edges of the frame and you'll see it's much better exposed by the HID. Yes LED lights have (many) advantages, but for raw light output I'm yet to see HIDs beaten. Maybe in the next couple of years .
http://www.lupine-lights.com/phpBB/viewtopic.php?t=1155Were the photos taken with the same exposure, ISO and aperture settings, or with a point and shoot camera or SLR in auto mode? Were they pointed at the same angle?
Everyone definitely has there own preferences as to what constitutes "good" lighting and I tend to agree with you that more diffuse lighting is preferable to light with high intensity concentrated into a smaller 'hot-spot" however I have to disagree with your physiological reasoning....The human eye is good at seeing in low light conditions, and the only reason as far as I can see, for a super bright light for recreational riding is if the beam were in such a shape that it provided even illumination for a long distance down a track.
I've found that if a light is too powerful, and does not have a good beam shape, it can light the area within 10 metres very brightly, and the rest of the trail comparatively dimly. The bright light causes your pupils to contract, meaning that the (minimal) lighting of the trail in the distance is rendered useless.
Funny you should mention that...Beam shape is crucial for good lighting. That's why car headlights aren't just made up of lots of little 12 volt downlights.
