Basically you can chuck any sized tubes in. I just head down to my lbs and pick up some 1.8/2.2 xc tubes. Work wonder, havn't gone back to dh tubes.I want to lighten up the rotating mass of my wheels and want some help to decide on what size tubes to throw in.
I'm running 2 ply 2.50 Nevagal Stick-E's and my question is not really what brand/model of tube to use but what is the smallest size that I could use in my DH bags?
Good to hear, I'll buy a 10 pack from Torp7. I've thought about going 1 ply tyres but came to the conclusion that I should keep the thicker 2 ply if I was going to run the skinny tubes. Are you (or anyone else) running 1 ply with skinny tubes?Basically you can chuck any sized tubes in. I just head down to my lbs and pick up some 1.8/2.2 xc tubes. Work wonder, havn't gone back to dh tubes.
If you really want to save some weight investigate into getting some single ply highrollers/minions. Can save almost a kg in tyres.
Kenda nevegal - 1200/1300
Hr/Minion singleply - 750/800
That's great info, thanks mate.I have run a 1.95 thornproof in my maxxis minions for a while, weight wise would not be far from the same weight of a standard 2.25 to 2.5 tube, however there is more chance of puncturing the 1.95 due to it stetching beyond its capability, either run a tubeless system or just stick with the normal 2.25 to 2.5 standard tube, play around with your air pressures, you will probably find with the kenda's that they need quite a firm pressure to stop pinch flatting as they have a more rounded tread profile compared to the minions as more air holds the profile of the tyrebetter which increases the traction capability of the kendas, minions however have a stiffer sidewall so lower pressures are more suitable for their construction.
hope this helps.
And you'll pinch flat like a mother fucker riding downhill. not recomeneded!If you really want to save some weight investigate into getting some single ply highrollers/minions. Can save almost a kg in tyres
Yeah, I used to do run single plys on my old atomik. I used to plow the shit out of that thing (Hence the name ) I only ever got afew flats (Mind you I don't really get many flats *touch wood*)Good to hear, I'll buy a 10 pack from Torp7. I've thought about going 1 ply tyres but came to the conclusion that I should keep the thicker 2 ply if I was going to run the skinny tubes. Are you (or anyone else) running 1 ply with skinny tubes?
As per above, I know people who get flats every weekend, wheras I seem to avoid them *touch wood*And you'll pinch flat like a mother fucker riding downhill. not recomeneded!
Well honestly I think you should visit this web site http://www.eatabagofdicks.com/ and pull your damn head in.Well honestly i think that if your looking for lighter tubes to lighten your bike.
You are really anal about about how light your bike is and your turning into a road biker.
Thats my contribution to this thread, hope it was healpfull.
