Marocchi Bomber CR shock spring advice needed
ForkinGreat
Knows his Brassica oleracea
Keen to buy the Bomber CR to try coil on my banshee prime. specs say I need 185x55 trunnion, but what coil will fit it?
acc to cyclinic's spring calculator I'll need a 650 or 700lbs spring, (because I'm a heavy khunt)
2.3in (stroke??) seems to be the closest thing to 55mm, (which is actually 2.165in)
itsajoke
DVO make a progressive with a different span to Cane Creek if you want that type of spring. NS Dynamics have them.
Delazy
Got a new bike!
I have a one ride old bomber 185x52.5 trunnion with a 650lb cane creek spring for sale atm... I was led to believe the only difference between the 52.5 and 55mm is a 2.5mm spacer under the bump stop which can be removed easily enough...I replace it with an EXT Storia v3 on my Norco Sight... message me if you are interested :)
coarselanguagw
oi oi .. I just went through this whole rigamaroll yesterday myself !!
If you go standard steel these are your options:
039-03-019Spring: [4.954 TLG X 1.385 ID X 650 lbs/in, 2.300 Travel] Black
039-03-009Spring: [5.701 TLG X 1.385 ID X 700 lbs/in, 2.550 Travel] Black
If you go with a "SLS" spring (which is just a more expensive and lightweight spring, which I don't think is good value if you are already a heaviery rider)
your options would be:
033-22-011Spring: 2019 [1.385in ID X 650lb/in X 2.4in/61mm Travel X 4.97in TLG] SLS
033-22-012Spring: 2019 [1.385in ID X 700lb/in X 2.4in/61mm Travel X 4.97in TLG] SLS
Go to this fox help page which has all the deets:
