Grover
FYI 11 speed freehub body now availabe. $39 on cycling express
http://www.cyclingexpress.com/?lang=en&p=productDia&proId=565389&proName=
I read somehwere that trainer road has multiple power curves (e.g. for different resistance levels). I am just waiting for my ebay purchased magnet & ANT+ USB to arrive to investigate further.
Hi guys,
Re: Trainer Road - I got the power curve information from the manufacturer of the D2R Shadow, then gave that information to Trainer Road and they added it into the software.
They list 5 supported resistance levels - Resistance 0, 4, 8, 12, 16. These correspond roughly to the number of 'clicks' on the resistance lever on the D2R Shadow (i.e. Resistance 8 = 8 clicks, or about half way around the resistance lever). When you setup Trainer Road, you tell it which resistance setting your are using (so you can't change the resistance setting mid-workout).
Yes you'll need the ANT+ USB and magnet per Cave Dweller's post here.
The D2R Shadow + Trainer Road is a great value training combo - I'm very happy with it!
Cheers
Steve
.........I have thought about a slight variation of your set-up. Instead of buying another Garmin/Ant+ speed pickup to put on the trainer, I was hoping I might be able to 'magnetically bridge' the 10-15cm distance between the flywheel and where my regular speed/cadence sensor is on the rear stay. Hopefully just a bit of steel bar that spans the outside of the flywheel cover (mega magnet passing underneath) to the tip of the pickup.
Forgive the thread dig, but a few questions for the others with this trainer who run a power meter -
Do you find it difficult to hold powers for certain lengths which are pretty simple on the road? For instance, 2x20mins at threshold are unachievable on this with the resistance pumped up enough to have a normal cadence, yet are, although a decent session, very achievable on the road? Harden up you might say, but I'm pretty sure I'm tough enough for this. I've done them on other trainers with no music, tv, fan etc..
I finally cracked it tonight trying to finish a 3x10min set at threshold, when I couldn't finish the last one.
I've owned other trainers (rear wheel based, fluid and magnetic) and they were far more ridable at those sorts of power zones than this one. Is it something to do with this power curve you guys are talking about?
I'm currently running a stages..
A penny for your thoughts?
Anyone got idea of how Trainer Road (TR) calculate the virtual power from speed sensor? I mean without the rear wheel, TR could determine it based on a speed from sensor that has an assumed diameter. To get the correct virtual power, what is the wheel circumference value that should be set in TR when using D2R Shadow?
By the way, you dont really need a giant magnet to be zip tied to the flywheel. I just recycled a strong magnet from desktop hard drive and stick it behind the steel plate which rotate together with the cassette and any magnetic speed sensor mounted on the cover surface should be able to detect it.
sorry for raising up this old thread - but i am in a similar situation with my flywheel / belt driven spin bike.
I already have the Wahoo RPM ANT+ sensor connected to the crank and working well.
I do not have any speed sensor yet, but need it because I want to use 'cadenceVR' SW which calculates theoretical Power.
The flywheel is front mounted.
Questions on where/how to mount this speed sensor and the ANT+ brand of this speed sensor?
Splasher
This modification for fitting an 11sp Cassette worked great! I was exploring whether changing the free hub was possible and came across this post - fantastic! Cassette is all fitted and working! Thanks! Will try the speed sensor when I come across a cheap second one to attach to the trainer - interested in knowing how you attached it to the casing though?
Hi Steve, I just saw this post.
What I did was to drill a hole through the flywheel and into the inductor ring. I tapped the hole and then threaded in a stud and loctite in place. You may need to grind down the inner and outer ends of the stud, in needs to be flush or it catches on other bits of the trainer. I put one each side, 180 degrees apart, works fine.
You can also now buy an 11speed upgrade for the trainers from cycle express. I have bought one, when the cluster wears out I will change it over. https://www.cyclingexpress.com/?lan...ow-Trainer-Shimano/SRAM-11-Speed-Freehub-Body
