My Bikes
921812.yr10
this is my new giant glory
size L
colour Blue / Black
frame ALUXX SL alloy Maestro 8.8" of travel, 150 O.L.D. rear spacing
fork Fox 40RC2 w/ti spring, 20mm t/axle, 203mm/8"
rear shock Fox DHX 5.0 coil w/adj. ProPedal
rear derailleur Shimano Saint Shadow
shifters Shimano Saint rapid fire 9speed
crankset Shimano Saint Hollowtech II 36T
bottom bracket Shimano Saint Hollowtech II
shift/chain guide MRP G2
chain Shimano XTR
cassette SRAM PG-970 DH 11-26T
brakes Shimano Saint 4piston Hydraulic Disc w8" rotors
brake levers Shimano Saint
hubs Shimano Saint thru axle
rims Mavic EX721
spokes Sapim Race 14/15G
tyres Fr: Maxxis Minion DHF 2.5 3C | Rr: Maxxis Minion DHR 2.5 3C
pedals straitline
h.bar/stem Raceface Atlas low rise/Raceface Diablous D2
seat post SDG I Beam
saddle SDG I-Fly
grips Giant lock-on metal
This is my SE DJ-flyer
It runs super smooth
Might get higher rise bars though
FRAME 100 Cr-Mo, Integrated Headtube Fillet Gussets
FORK Marzocchi Dirt Jumper 3, 20mm Through Axle, 80mm travel
HEADSET Tange 1-1/8" Sealed Integrated
HANDLEBARS SE 1.25" Alloy Riser Bar, 25.5" Wide
STEM SE Front Load Shorty, 1-1/8" Alloy
GRIPS SE Bubble Jump Grip
BRAKE LEVER Tektro Auriga Comp,160mm Disc. soon to be avid elixer r
BRAKE(S) Tektro Auriga comp, Hydraulic,
SEAT SE Pivotal w/Custom Cover
SEAT POST Pivotal Micro Adjust Aluminum 25.4
CRANKSET SE 3-pc CR-MO, 175mm, Euro 4 Sealed Bearing, 30T Alloy
CHAIN KMC Z510 Silver
PEDAL X-Pedo MX-6, Aluminum, Cr-Mo Axle, Removable Pins
RIM Alex FR-32, 36H Double Wall aluminum, With Eyelets, Stainless Spokes
FRONT HUB SE Alloy Sealed Bearing Disc, 32H, 20mm Through Axle
REAR HUB SE Alloy Sealed Bearing Disc, 32H Alloy cassette, Nutted w/ 15T Cog
TIRES 26" Kenda K-Rad 2.3 Front, Kenda Kiniption 2.3 Rear soon to be kenda small block 8 front, intense micro noby rear.
COLOR Chillin' Blue
this is my road bike.
not shure what it is, any help?
im gonna restore it
Im gonna spray the frame gloss black and rmove the rust from everything
also, new chain, new cassete, rd cable
who...?
Wasnt a big fan of the 09 glory paint work when it first came out with the blue rims (I think) and the black and blue frames but this one is nice looking with the silver rims i think it wouldent look to bad if the rims where highly polished or chrome but that just me.
kill_switch
Dead-set Idiot
Dose any one else find that glorys are noisey because mine is quite loud in the rear end, any help?.
Ive warped the stays of my rear end in bike tubes. Ive just the other day also warped the part of the frame that runs between the top and bottom stay that the chain runs directly past. It should help. You can also get the fuzzy part of some velcro and put it in your chain guide where the chain rubs. I havent tryed this, but im about to give it a go.:eek:
Nice bike btw
-Brent
milkybarkid
Nice bike btw
-Brent
Yeah i have that problem too, I'll try the Velcro thing...Thanks in advance mate.
dhJAC
Squid
Sweet bike mate I love it . I was at the you yangs nats last year and they were the most silent riding bikes there. Good luck and ride hard!
chops
hey i have the same bike it is such a good ride.
with the noisy rear end i wound in the B tension screw on the derailleur and that fixed so now it is smooth as silk.(but then i blew out my shock and cracked my rim:()
921812.yr10
yeah thats a good idea thanks mate will do tomoz
and that thanks for all the comments
921812.yr10
When can u ride againn?
yeah it wasnt actually a fractured humerus it just ended up being bruised muscle tissue which is really good for me.
so i just gotta take it easy for a few more days.
and i will be able to ride the sushine series at illanbah so im pretty stoked :D
921812.yr10
yeah tried this but it didnt work any more help on the noise thing would be great
I think it is something to do with chain slap
