DOM
http://www.pinkbike.com/modules/news/?op=articleview&id=1542
Thought this was worth a discussion .. frames look quite interesting.
Rik said:if you're going to have horizontal, at least make it "infinitely" adjustable to allow for single speed use :twisted:
:shock:rad rob said:you should be able to get near to perfect tension on any gear combination.
rad rob said:and as for the bolt up sliding dropout setup, saying this will effect single speed use is plain wrong. each chain link is 1/8" long, meaning no matter what combination of gears you use, your chainstay length will fit into some multiple of 1/8". and to me, those bolts on the dropout look to be 1/8" apart. thus meaning, you should be able to get near to perfect tension on any gear combination.
rad rob said:obviously the gears = no thing in the table at the bottom is a fuckup.
as for the fake weld, it says for asthetics and performance, so i'm guessing it does perform some structual function.
as has already been shown by the letoy 4 prototype, bolt on dropouts are going to be the next big thing. they allow for perfect calipar & derailer positioning, while still allowing for adjustable chainstay lengths and singlespeed.
it'd be fair to assume, someone spent a lot more time thinking about the design of this frame, then you did thinking out your post bitching about it.
