There are as many bolts and screws torqued to the optimal tension on a World Cup DH bike as there are on a light XC bike.
Look as it as the perfect tension to get 100% out of the bolt, 100% out of what the bolt is holding and the highest probability of the rider not having any of their parts fail.
The other option is to make stuff out of thick steel and use high tension bolts... and enjoy your 25kg bike.
Just used mine this afternoon to torque up pivot bolts, I don't use it very often but dont fancy stripping suspension/Pivot bolts or the frame that it screws into.
Sure I respect that. And again, I understand the implications. For me, for carbon bits is a needed due to the characteristics of the material.
On alloy parts I've never used one.
Most L shaped allen/hex wrenches start flexing when they get close to the recommended torque for the bolt, you can feel it in your hand. Most wrenches have a handle size that is pretty much according the amount of torque you can put with/on them. Problem start when you have a 1/2" driver with a 4mm bit to make a silly example. You can easily damage something in that situation.
Flow-Rider and Binaural make pretty solid points too regarding cross threading and damaging threads.
Thread preparation is key.
