slowmick
38-39"
Welcome to Rotorburn good sir. At 110 kg kitted up I wouldn't consider taking your demo for anything other than a spin around the car park. I had a look at The Ride webiste last night - they have another Demo II but it is only a medium. given spring availability for the Ohlins I should probably look at something more readily available. From reading the manuals for the Boxxers i think i will need to get an air cartridge as the springs don't seem to go above 90-99 kg (Black X-Firm). so it's either air or less pies.slowmick, that was my Demo 8 II you rolled around the carpark on. I did consider letting you do a run on it but since the suspension was set up for a 89kg person it really wasn't going to perform at it's best under you. That said the Aurums in the ATC hire fleet are not really set up for the heavier rider either. My Demo was a slightly used Ex Demo Fleet bike and it had been set up with a spring that was two increments lighter than what I needed. Once I installed a coil with a more appropriate spring rate the bike truly came to life. The coil would probably need to at least another 5 increments higher to get the spring rate in the ballpark required for your riding weight but I'm not sure the Ohlins range go that high. If your thinking about a Demo 8 visit a Specialized Dealer (one who has real experience in DH such as "The Ride" in Kew) and see if they can set you up properly on on a test ride which you can take away for a weekend.
Hope the rest of your Sunday went well. Cheers Mick
