ButtersNZ
Squid
I bought the Firebird because it offered the best compromise between DH and climbing ability. Shuttle services in my town are expensive and all the best trails require a good 600+ m of high grade climbing! I've only changed a few items from Pivot's spec. If I had more money there would be a set of Zelvy hoops on there - otherwise I'm stoked!
Frame - Pivot Firebird XL
Rear shock - Fox Float X2 w/climb switch
Front shock/fork - Fox 36 Fit4 w/MRP ramp control cartridge
Handlebars - Renthal Fatbar 35mm carbon
Stem - Renthal Apex 33mm
Headset - Pivot OEM
Grips - Ergon GE1
Saddle - Nukeproof AM
Seatpost - Fox Transfer 150mm
Front brake - Saint M820 w/metallic pads and XTR 203mm rotors
Rear brake - Saint M820 w/organic pads and XTR 180mm rotors
Cranks - Raceface Aeffect 175mm
Chainguide - OnOne Components
Chain - XTR 11 speed
Pedals - Brendog DMR Vault
Rear derailleur - XTR medium cage 11 speed
Rear shifter - XT M8000
Cassette - XT M8000
Front hub - DT Spline
Rear hub - DT Spline w/36t ratchet upgrade
Front rim - DT Swiss M1700
Rear rim - DT Swiss M1700
Tyres - 2.35" Schwalbe Magic Mary Trailstar (F), 2.35" Schwalbe Rock Razor SG Trailstar (R)
Total weight - 13.5 kg
