Chriso_29er
you might be better off doing a big fart before you start your ride, or better yet out of a corner. BRAP!
Tried this on a ride last night, I think it might have worked!
No, that does look like a good little upgrade. Depends how much they want to charge for it...Have a further look. Existing valves adaptable, it just screws in as a valve core. I don't immediately hate it.
Ok, thats cheap enough. Looks like its time for a pointless bling purchaseYou will need the pump head, or pump head conversion adaptor.
Schwalbe Clik Valve Conversion Set | SV | Valves with pump head adapter | 3542
The Schwalbe Clik Valve can also be inflated with conventional SV pumps. All you need is the pump head adapter, which can simply be plugged into your existing pump. It is then clicked onto the Schwalbe Clik Valve. Handling is intuitive and inflating the…www.schwalbe.com
The product of a partnership between Schwalbe and Clik Valve, the new product will be available from either brand starting in August or September,Ok, thats cheap enough. Looks like its time for a pointless bling purchase
Oh - will also need a mini pump... Not that ive brought it out of the camelback in a very long time. Suppose i could just keep a presta valve core in the camelback as well if it came to that.
Lies! You must need a gravel bike! NBD for @Haakon!When I'm commuting (ie not in the last month with this fucking RSV virus...) the roadie needs tyre pressures check every second day really. The roads are horrible and very pressure sensitive - ie run the 28mm tubeless as low as I can get away with without the handling getting screwy in the front. I can see me appreciating this.
You decide
I remove the core to inject or remove sealant already...
Takes 2 seconds to remove or install...
Are muc off also selling wheel balance kits to offset these chunky ass valves?
