My stabby mcstabber has boost standardPffft. What, with last year’s knife? Get yourself a universal stabba.
A new wheel size
700c vs 750D is not significantly different. It's more a case of "fark you all, we will make you buy new stuff, peasants!"I get anxiety when there is a bump to this thread.
Great if you are shaq proportions. Rest of us are fine. Why not just go 36er... oh wait...
When the fuck will they stop using the obsolete French sizing convention????
Probably about the same time Australia stops using the imperial system...When the fuck will they stop using the obsolete French sizing convention????
Not a new standard, but wowza, the claims in this one are pretty wild
Tubolight Diamana, the Fastest MTB Tire Liner because of Venturi Airflow INSIDE Your Tires!
All-new Tubolight Diamana is the fastest mountain bike tire liner in the world, harnessing Venturi effect airflow INSIDE your tires…bikerumor.com
If claims are true then I am going to run it backwards so I can travel back in time and put a stop to some of these bs standards.Not a new standard, but wowza, the claims in this one are pretty wild
Venturi would be slowing down, then speeding up, then slowing down again in his grave!Not a new standard, but wowza, the claims in this one are pretty wild
Sounds like it should be in the douche of the day thread...Not a new standard, but wowza, the claims in this one are pretty wild
Written by AI no sane human could think that one up.Not a new standard, but wowza, the claims in this one are pretty wild
I mean, I'm no Fluid Dynamics Engineer, but air under pressure will be in every nook and cranny in that tyre. A 29 x 2.5 tyre has about 4litres of volume...a litre of air weighs 1.2ish grams. Filled to 30psi, thats 9.6grams of air, which they are not removing...just somehow manipulating it a bit, are they trying to make it spin with the tyre? would it do that already? or just be turbulent? In any case I've probably over-thought this already and you might be better off doing a big fart before you start your ride, or better yet out of a corner. BRAP!
Helium!!! Weight weenies will go heliumOr fill your tyres with NOS to go faster.
