pistonbroke
You lose points for the pox backdrop and not having your valve stems at 6 o'clock. Chain should also be in the big ring.
B-
B-
I will never make a good roadie :yuck:You lose points for the pox backdrop and not having your valve stems at 6 o'clock. Chain should also be in the big ring.
B-
do you happen to have this review handy?HED are doing a wide rim and I read a review saying that a 23c Schwalbe Ultremo measured 27mm across when on the rims. Massive!
My next wheels will be the big footrpint HED's.
The washer on your cable anchor is on the wrong way. Needs to be rotated 90 degrees clockwise so the locating tab is pointing upward, parallel to the cable. Buggers the leverage and the cable the way it is now. :nerd:
Worked fine for quite a few thousand kms, but you'll all be happy to know the cable has been replaced, and also has a cap on the end now :thumb:The washer on your cable anchor is on the wrong way. Needs to be rotated 90 degrees clockwise so the locating tab is pointing upward, parallel to the cable. Buggers the leverage and the cable the way it is now. :nerd:
niiice! i've got some LB 45mm U-shaped clinchers coming as well. should get sent any day now... mine are on novatec disc hubs for my cx/roadie though.BMC SL01 that I've had for about a year now.
Just did a full rebuild with a few upgrades:
Light Bicycle 45mm U shape rims UD Gloss finish with Bitex hubs
Ultremo tyres
Speedplay stainless pedals
Bontrager grippy bar tape
Dura ace chain
New cables all round
Lost 800grams from previous build. Wheels are incredibly stiff and fast rolling, am yet to take them for a proper spin but they feel good so far. Included with the wheels were dura-ace carbon pads and braking seems to be fairly reasonable, will find out once I hit the hills.
I apologize for the shit photo
Keen to hear how you find the wheels, I was toying with the idea of trying those for a tubeless setup.BMC SL01 that I've had for about a year now.
Ultremo tyres
Dura ace chain
Was going to have a crack at it, using Bontrager rim strips and Bontrager R3 tubeless tyres. But if it didnt work I would have been stuck with the tyres that are impossible to mount without 40 tyre levers and a hydraulic press....Keen to hear how you find the wheels, I was toying with the idea of trying those for a tubeless setup.
Negative on the tubeless. Maybe in the future, but having enough troubles with tubeless on my mtb to worry about trying to set these up tubeless. Did another 50km this morning, cant get enough of these wheels!Have you tried setting them up tubeless? I'm considering a set mainly because I'm curious about just how a wider, tubeless setup could ride.
Set them up tubeless and tell me if they're any good!Light Bicycle 45mm U-shaped clinchers finally arrived. damn chinese new year.
That is f&%king awesome! You got a build thread?Light Bicycle 45mm U-shaped clinchers finally arrived. damn chinese new year.
i'm tossing up going tubeless once these gatorskins are dead. still got a few k's left in them though.Set them up tubeless and tell me if they're any good!
haha, cheers. if it's worth doing, it's worth overdoing!jesus mitchy, if that got any lighter or more aero, you'd need a pilots license. nice work, and the purple anno highlights are a nice change from the 100% stealth black you see everywhere.
it started life as a flat bar commuter, and has evolved into basically a disc CX with 28mm tyres. it does get taken down dirt tracks and the like, so whilst predominately ridden on the road it's not 100% roadie.That is a VERY interesting roadie. Single ring, disc brakes. I like it.
