Post Your XC Machine
ScooterXC
Thanks, I love it. Selle San Marco Aspide - Firm but fair.
I've got a Sele Italia SLR. best thing other than a Flite i have ever used. I've sat on Gobi's for almost a year and then i swaped. Never going back:D. Until it snaps like the one i saw at GMBC crazy 6 hour.(how did he manage that??)
How much does your s-works weigh?
check out my beast on pg 107.
:cool:
Antsonline
Something different
Hi - here is my 2'nd bike. Its a bit different from my Spark, but very cool, and a real head turner. Sadly its up for sale as I need funds for a full 29er with gears (Niner), which will be posted here in due course! :cool:
Mudguts
Cannon Fodder
Carbon Avanti Competitor 2.0
My new Avanti Competitor 2.0
Frame: ADT XCR1 T2T Carbon
Fork: FOX FRL 100mm Air Travel w/ Lockout
Front Derailleur: Shimano XT
Rear Derailleur: Shimano XT
Brake Levers: Shimano XT Hydraulic Disc
Shifters: Shimano XT Rapid Fire Plus 27 Speed
Crankset: Shimano XT 44/32/22
Brakes: Shimano XT Hydraulic Disc
Hubs: Shimano XT Wheelset
Cassette: Shimano XT 11-32T 9-Speed
Handlebar: Easton EA30 Flat 31.8mm
Grips: Zero X-Grip Lock-On
Handlebar Stem: Easton EA50 Forged 31.8mm
Rims/Wheel Set: Shimano XT Wheelset
Spokes: Shimano Stainless Steel
Tyres: F/Maxxis-Crossmark R/Specialized Crossroads
Saddle: Zero Gamma-X
Seat Post: Easton EA50 31.6mm
Bottom Bracket: Shimano XT
Headset: FSA Integrated 1-1/8"
Chain: Shimano HG53
Total weight - 10.75 KG
fraal
Squid
My new Alfined HT!
Hey y'all,
Just finished this off on the weekend!!! Internal gear hubs for the win!!
It's a 2007 Trek 8500 hardtail frame with shimano Alfine gearing.
Sorry, but no pros/cons at the moment, maybe in a couple of weeks. But I did conquer the biggest hill in Hobart on it yesterday ;)
Gripo
Too right
I see you're running full length gear cables, surely there's a few grams that can be shaved right there! :p
Too right, in the end it must be an enhancement though and just imagine all that dust that'd collect and weigh down the bike and slow shifting.. pffft.
gixer7
I think we have us a spammer in our midst!
But not anymore - toodles has banned the arseclown! Good riddance too.
Gone Riding
Well it's been near on several weeks since build up and the bike is still amazing me. Probably not so much "the frame" itself but how a lite' bike can alter your thinking of what was speeds are possible when pedalling singletrack and climbing capabilities that you can obtain without going to granny.
I've ridden a 6hr with which I set my fastest laptime late in the day and have had numerous trailrides. This isn't supposed to be my everyday trailbike but I'm finding it hard to leave it at home as I find my BLT2 @ 28.6lbs too slow and heavy?
The last several weeks has also had me chasing grams (purchased a set of kitchen scales :eek:) to try and get it a little lighter. A set of race only tyres (Schwalbe rocket ron for the front and racing ralph on the rear) saw an instant loss of 200g. With a change of brakes, seat, rear derailleur, bars and Ti bolts for the Thomson stem/seatpost/seatclamp/cranks etc. lost another 150g+.
I've also lost 80g by going 2x9 after some experimentation, settling on 36/22t simply because no tracks I ride is a 44t and the lower 3 on the cassette ever used. Besides I can spin a 36x11 up to 40kmh with a tailwind.
Anyway for the weight weenies here's some numbers.
Ready to ride - 23.6lbs
Without chainstay protect/bike comp - 23.2lbs
Without above and pedals - 22.6lbs
Nice ride Gripper... how do you find the Rocket Ron (F) and Racing Ralph (R) tyre combo? I've just set myself up with the same but in 2.25 UST both ends... I'm hoping they ride as well as the hype would suggest!
PS - Are they 26x2.25 on yours?
Landon
XC Machine
Here's my Spark in the current setup.
Frame: Spark Team Edition - Medium
Shock: DT XR Carbon
Fork: SID WC
Wheels: Crossmax SLR
Brakes: Juicy Ultimate
Rotors: Hope Pro 160/140mm
Bars: FSA K-Force XC
Stem: Syntace F99
Seat: Selle Italia SLR Kit Carbon
Cranks: XTR
BB: Enduro Zero Ceramic Hybrid
Chain Rings: Specialites TA Chinook 30/42t
Pedals: Time ATAC XS Ti Carbon
Front/Rear Derailleur: XTR
Cassette: XTR 11-32t
Shifters: XTR
Chain: XTR
Tyres: Hutchinson Python Tubeless Ready 2.00
On The Scales: 21.35 lb (just under 9.7 kg)
Bodin
GMBC
Good to see you left some room for upgrades... Pffft!
Have to say that, as an observer, the overall colour scheme utterly sucks, but at that weight (a full 20% less than my "race" bike) I wouldn't give a sh*t what colour it was, because you'll be going too fast for anyone to notice.
tudorsi
Frame -Specialized 100% Cr-Mo, double-butted HT/DT, externally relieved HT, disc mount, 6mm offset horizontal drop out for 26" wheel w/ single- and multispeed hardware, disc only
Rear shock -N/A
Front shock/fork -Marzocchi DJ3, 80mm, Cr-Mo steerer, 32mm Cr-Mo stanchions, magnesium lower, fixed rate catridge damping, coil/mcu w/ preload adj., "stiff" spring
Handlebars -Specialized alloy riser bar, 31.8mm, 55mm rise, 680mm wide, 8 degree back sweep, 8 degree up
Stem -Specialized aggro, 3D forged/CNC, 4-bolt, 35mm length
Headset -Tank FX, 1-1/8" threadless w/ hollow bolt
Grips -Fuse BMX, single compound, closed end, 140mm
Saddle -Specialized Fuse Lo Pro, 8mm rails, PVC bumpers front and rear
Seatpost -Specialized alloy two bolt, no offset, micro adjust, 30.9mm
Front brake -Avid BB5, mechanical disc, caliper/adapter w/ 160mm G2 Clean Sweep rotor
Rear brake -Avid BB5, mechanical disc, caliper/adapter w/ 140mm G2 Clean Sweep rotor
Cranks -Fuse tubular heat treated Cr-Mo 3pc.
Chainguide -34A w/ poly bash guard and Specialized ISCG chain guide
Chain -KMC X8 w/ reuseable Missing Link
Pedals -Specialized alloy platform, 9/16"
Front derailleur -N/A
Rear derailleur -SRAM X-5, short cage
Front shifter -N/A
Rear shifter -SRAM x4, 8-speed trigger
Cassette -SRAM PG-830, 8-speed, 11-28t
Front hub -Specialized, forged alloy, high/low flange, 36h, nutted 3/8" axle
Rear hub -Specialized Hi Lo, forged alloy, double sealed, ground race, cassette, nutted with 3/8" axle, 36h
Front rim -Specialized/Alex P.Disc AM, double wall disc w/ eyelets, 36h
Rear rim -Specialized/Alex P.Disc AM, double wall disc w/ eyelets, 36h
Spokes -2.0mm (14g) stainless
Nipples -Unknown
Tyres -Specialized Rhythm Lite Control, 26x2.3", 60TPI, aramid bead
Tubes -Specialized schraeder valve
Total weight - Unknown
gixer7
tudorsi,
That is no good, no good at all. You can't tease us with a (highly detailed) spec list and then put up no photo.
Please rectify - I want bike porn!
tudorsi
tudorsi,
there you go one problem i just noticed this is post your XC machine this is a DJ woops
