Thanks mate! Was really happy with those ones. A couple blew out when putting the actual floor in, but hopefully I can tidy them up afterwards for a nice finish. Fingers crossed everything lines up when the body goes back on. It all looked pretty good to me and it helps that the body to pan holes are oval, so hopefully enough wiggle room to get it on place.^^^^^^ nice plug welding there chap. always a pain when welding in new floor pans, a little bit of jiggling n twisting is sometimes needed when the body comes back on the pan.
vee dubs and land cruisers, you guys are killing me. I gotta finish one so I can buy the other!
2" and 33's is good. A mate has tackled some pretty hairy climbs in his 80 with the setup, the only blokes that made it up were heading I'll modded, fr different lock bigger lifts 35's but he damn near got it, everything else was a breeze, you'll love it.
Binner, engine pics! I think my plan now is a 1916cc tuned for daily with enough balls to cruise at 110 and surprise a few commodores but nothing stupid fast. Apparently aiming for 110-120hp. Should be plenty.
In my attempt for completely stereoless looking interior I've got the tweeters behind the bamboo headliner, still great sound but hidden, main door speakers hidden with thin metal bar across material to protect from knees and and amp under the rear seat. Seems silly though, head unit has rca leads up a pillar, through roof down b pillar into floor to the amplifier, and then the speaker wires runs back the same way to the dash then down into the doors!
Edit: finally went through with this, only be on for 6 months because of ludicrous price.
Sent from my SM-G935F using Tapatalk
Buying a snorkle won't fix the issue. I'm not familiar with gas but a backfire is gas detonating in the intake system so bad tune or leak needs to be fixed. Definately a job for a professional, personally I'd get rid of the gas as it seems like a reliability issue on a car you'll be driving into the bush.First mechanical issue with the cruiser!
LPG backfired and smashed the lid of my airbox. It had some clips on it but the previous owner seems to have added BOLTS which made it go bang rather than just popping the lid off like it did in my parents Falcon. New airbox is $120 and I've enquired about buying just the lid from a few wreckers.
Questions for the more knowledgeable:
1. I drove about 15 km's on sealed road without realising the lid was off. Not particularly dusty (it was raining) but my engine bay was quite dirty (dried mud). Anything I can do after the fact to reduce engine damage? Obviously next time it backfires I'll pull over and check it immediately.
2. A mate has a pod filter that is the right size - any real harm to putting this on for a week or two of on-road use while I wait for the airbox to arrive/find a better solution?
3. I have wanted to install a snorkel anyway - maybe now is the time? Would I be best to buy a snorkel and some sort of aftermarket airbox/in-line air filter and fit it all up now, rather than buying an OEM airbox and having to butcher it to fit snorkel?
4. How do I stop this from happening again? Is there some sort of one-way pressure valve I could maybe install somewhere along the intake that will let some pressure out without the airbox detonating? Would an LPG tune help? It's backfired twice in 1500kms. Just don't want to have to buy a new airbox every couple of times it happens.
What involve more legal issues, building a car or heavily modifying a car into a new car? I'd say building something would be the easy part, legalities will be the difficult stuff.Doods.
I posted ages back on this thread but didn't get much into it, but this time I've bought some books on chaises, aerodynamics and etc.
As I had a thought, instead of buying a rolling chaises, the house i'm at came with a bomb (Old 90's Corolla or some shit) and the thought came to me,, could I perhaps get the engine going (Or replace with it with used engine from another old car if fixing the engine becomes too much) and modify the chassis/body work to what I would like?
Or would this idea not work?
Yeah it would have been a sweet plate till this came today. TETNUS is taken, might try RSTBKT.Awesome plate for a rat!
Heavily modifying into a new car.What involve more legal issues, building a car or heavily modifying a car into a new car? I'd say building something would be the easy part, legalities will be the difficult stuff.
Carolla chassis would be a good start, small light, convert to rwd easily enough. Would love to see this.
1. No, but unlikely damage doneFirst mechanical issue with the cruiser!
Whether a track or road car, engineering certificate is required for that level of mod.Heavily modifying into a new car.
I want to turn it into a rear engined car and style it quite agressively, think veneno/p1, or I may tone the complexity of the styling down to say mustang but with a bit more aggressiveness.
As of now, it will onlt be done as a project just to see if I can even do it, maybe take it to the track to fine tune it.
If all works out, I'd consider building something from scratch so it can be regoed as I imagine a heavily modified frame would be next to impossible to register.
Been doing heaps of googling on frames, frame styles, etc but i think I'll get a better idea with these books.
You will not stop it, I've seen some of the best systems money can buy and they still back fire every now and then, blown rear main seals out, head lights blown clean out of the car, sumps and tappet covers looking like balloons. If there is any small problem with the motor, gas exaggerates it. You need to run an airbox that has springs on it instead of clips, even if you convert one yourself. The LPG cheapness is not cheap, you always have to make sure your ignition system is prime and the gas does not lean out.3. I have wanted to install a snorkel anyway - maybe now is the time? Would I be best to buy a snorkel and some sort of aftermarket airbox/in-line air filter and fit it all up now, rather than buying an OEM airbox and having to butcher it to fit snorkel?
Thanks mate! Was pretty scary up to the first weld, but after I got the settings on the welder dialled and the confidence to attempt it, I was good to go. Hopefully it starts coming together again soon. Haven't even looked at engine or anything yet, just rust and body work so far, but every bit is a step closer to rego.Bloody hell elbo that's one hell of a job, good stuff!
I reckon it'd be better anyway with it's original plates. Can you find it's original number (assuming it was sold in your state...)?Yeah it would have been a sweet plate till this came today. TETNUS is taken, might try RSTBKT.
It has one original plate, I like the style but not sure I can get it in this style, haven't seen one like this in a long time. As for patina, I'm not right into the purposeful rusting.I reckon it'd be better anyway with it's original plates. Can you find it's original number (assuming it was sold in your state...)?
Get that as a personal plate and "patina" it as far as you'll get away with.
While that plate is old, I doubt it is original. It's probably just a 'next in line' update from when that style was around. Bicentenary 1988 perhaps? Seventies would have had rego starting with G or H probably in NSW. I had a 1974 car with GZP??? plates, mate had a '76 with HUT???It has one original plate, I like the style but not sure I can get it in this style, haven't seen one like this in a long time. As for patina, I'm not right into the purposeful rusting.
You'll be able to find the specs on carsales if you know the model and year.Soo,, where would I get a set of spare rims with tires, would local tire shops give up the correct size or should I consider making a craigslist etc ad in search of something?
