fairy1
Banned
You might just want to inject water with no meth, Methanol is used in petrol engines as it has a greater cooling effect than petrol and increases octane at the same time. If you inject water only it will provide more cooling for your exhaust valves and it ups the effective compression slightly as the water does not combust.
24 PSI will be plenty, if you can get a brass/stainless misting nozzle for a greenhouse you can get decent mist from 10PSI. If you spray pre turbo it will be smashed by the impeller and atomized further, as long as you don't spray a direct jet at the impeller it won't suffer from erosion.
You could also run a simple injector setup using an injector a TPS and a fuel pump. You can get an injector driver from Jaycar for sweet FA and use a TPS as an input to fire the injector, it won't be as good as a variable setup but it will work.
Also if you use a petrol fuel pump or injector you will have to put a small amount of machinists oil in the water.
