pistonbroke
Just found another one for $600 that I'll use for spares.
Won't the same parts just fail from both of them ? You could just sell themJust found another one for $600 that I'll use for spares.
The in-laws have 140 acres that is the ideal location for such a deathbed of British motoring.Won't the same parts just fail from both of them ? You could just sell them
both and buy a Toyota ... Otherwise, I foresee a landrover graveyard building !
Check the rear tail shaft is tight and the condition of the uni's, then check the control arm bushes. Have a feel of the rear wheel bearing also.The beloved 105 Cruiser has developed a little bit of an issue where she squeaks/rattles when engine braking (going downhill, in gear). Especially noisy in 1st gear low range on bumpy ground (maybe just because theres no wind noise). Around the same time I've also noticed she wobbles/shudders a bit taking off in 1st... especially on hill starts but also does it on dead flat ground when you release the clutch slowly at idle. Not so much in "normal" driving.
Any inspiration? Thinking engine mounts?
Bonus question - if it is the engine mounts, is lifting the engine to replace it by running my winch up through a winch block around a gum tree branch and back down to the engine lifting points a bad idea for any particular reason? I dont have easy access to an engine hoist.
Strip everything down. Put all the bits in a box (or better yet wire baskets) and take them to your local engine reconditioning shop and ask them to put it all through their hot wash. Its the only way to fly when cleaning engine parts, life is too short to do it by hand!!Beetle engine is out and split. Everything inside is pretty shit hot, can probably reuse the crank and camshaft, with everything still attached no worries but need outside opinions. Will have pictures tonight. Main question, massive carbon build up on the heads and valves. Valves and probably guides will get replaced, but how do I safely clean the carbon off? Was thinking of getting everything vapor blasted but better check first.
I wanna see pics of # 3 cylinder and piston, do all the bearings spin freely on the crank?, show me a pic of the split bearing.............. info info info :eagerness:Beetle engine is out and split. Everything inside is pretty shit hot, can probably reuse the crank and camshaft, with everything still attached no worries but need outside opinions. Will have pictures tonight. Main question, massive carbon build up on the heads and valves. Valves and probably guides will get replaced, but how do I safely clean the carbon off? Was thinking of getting everything vapor blasted but better check first.
Get some shots tomorrow. Cam bearing mint, main bearings and thrust way too loose and case has high point from the oil Valley in the bearing. Assuming a grind down 0.5mm and get OS bearings? Gunna go back to stock 1600cc and learn that first before trying a stroker.I wanna see pics of # 3 cylinder and piston, do all the bearings spin freely on the crank?, show me a pic of the split bearing.............. info info info :eagerness:
Only noticed that after posting that, too. Will have a good check tomorrow.Heads look ok. Is that a crack around the main bolt?
Hahaha, true salesman. Kind of excited about rebuilding myself now, proper built not bought.what about the last main bearing that is on pulley end of case, and check all your oil galleries for blocks, what about the oil pump?
How about you buy a nice nearly finished rebuilt 2ltr Kombi engine to dump in the beetle :happy::happy::happy::whoo:
I reckon with the right tuning you can squeeze 65/70 HP out of it
