Don't do it. 30mm bbs just creates all sorts of problems. The Hope bsa30 bbs are the f!%^ing worst.Hope cranks are cheap on CRC, more research required.
Check AliExpress specs VERY closely. I almost bought hope hubs off there for $50 cheaper than elsewhere....but noticed in the very fine print they were not genuine.I can't rationalise buying a Rascal and eeWings
Found some Mt900's on AliExpress but the weight saving is fuck all, I just need to get over not having matching XTR on the bike and put some XT cranks on there. I buffed the 'Deore' of my 4 spot calipers, maybe I can just make the XT cranks into non series cranks.
The bigger issue is who is going to buy my Optic frame, I could keep it for the young bloke but he's still in the bad books after fucking the rear mech on it a couple of weeks ago.
Are you sure? I thought the MT900 still had the old pre-load mechanism and were a hybrid (new colour, direct mount, old pre-load) as you mentioned due to the plant fire?MT900 is XTR that didn't get the proper surface finish because that part of the factory burnt down. Structurally it is the same thing.
Carbon cranks are a fundamentally flawed design. I love the stuff, but there are some applications where it's just not the right stuff.
They do (edit: currently have them on the Marino, definitely not new preload), though still direct mount chainring. Also have a slightly wider Q factor.I thought the MT900 still had the old pre-load mechanism
Pretty sure I read from Shimano that MT900 and M9100 are the same crank, just that as a result of the fire they weren't able to produce the intended finish for a while, hence the non-series designation.Are you sure? I thought the MT900 still had the old pre-load mechanism and were a hybrid (new colour, direct mount, old pre-load) as you mentioned due to the plant fire?
Wouldn't that technically make them a no-go-zone?Check AliExpress specs VERY closely. I almost bought hope hubs off there for $50 cheaper than elsewhere....but noticed in the very fine print they were not genuine.
Was for me.Wouldn't that technically make them a no-go-zone?
Don't blame you @moorey I want my counterfeited stuff to have the correct logos or I'm not in either.Was for me.
When is the rascal turning up?XT shit has been ordered, will be here Friday. The weight difference was negligible and I'm not brave enough to buy expensive stuff from AliExpress.
Where did you order them from? Can I ask how much?XT shit has been ordered, will be here Friday. The weight difference was negligible and I'm not brave enough to buy expensive stuff from AliExpress.
Lifetime warranty on the Rascal.Don't worry, I'm hatching a plan.
I really like the look of the new Salsa Blacksomething but the warranty is a bit scary.
They aren't really cheap any more, they were $300 with the chain ring. Same price at Pushys or Bike Bug. I could have got them from Merlin a bit cheaper but with the current shipping issues from UK it's not worth waiting.Where did you order them from? Can I ask how much?
I'm trying to resist, you are not helping.Lifetime warranty on the Rascal.
You’re welcome. Did I mention that Felix worships the Rail?They aren't really cheap any more, they were $300 with the chain ring. Same price at Pushys or Bike Bug. I could have got them from Merlin a bit cheaper but with the current shipping issues from UK it's not worth waiting.
