Greetings!
So, the dust seal on my '06 RP3 popped out and in an attempt to tap it back in, I took a chip out of the shock shaft and now all the air leaks out.
To get the RP3 shaft replaced, I'm looking at around $150.00-$200.00 dollars. For $350.00 I can get a brand new '09 Fox VAN R coil shock to replace the RP3.
In terms of performance, is there much difference between these shocks? From what I can tell, they both have rebound adjustment and they both have propedal. The only difference I can see is the RP3 has three firmness settings (I never change it from medium) and it weighs 130grams less.
In terms of feel, what can I expect by changing to the coil? Given an air shock increases the spring rate as it compresses, am I more likely to bottom out on the coil?
If riding style makes a difference, I'm riding an '06 Dawg Primo and doing some pretty aggressive AM stuff and light freeride with my biggest drops being around 5.5 foot - I frequently bottom out the RP3.
Any thoughts/opinions would be great.
Thanks,
Scott.
PS: I did find helpful threads like this http://www.farkin.net/forums/showthread.php?t=143482&highlight=Air+Coil but I'm after some advice on the specific shocks listed. Ie mid range air vs cheap coil.
Thanks,
Scott.
